Question about Intel D845GVSR Motherboard
Why the processor overheated on boot
Sometimes don't boot {processor overheat}, but it is very cold.
    Problem Solver:
  • 13 Answers
Check settings in bios
Posted on Jul 16, 2009
Engine overheats and heater blowing cold air
You have air trapped in system , change thermostat , bleed air from system , let it run hot while adding coolant with blower full blast on all front and rear heaters .
Jan 23, 2013 | 2001 Audi A6
My car is overheating
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 16, 2012 | 1998 Chevrolet Cavalier
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Jan 30, 2012 | 2003 Chrysler PT Cruiser
Car over heating
For car running hot and overheating issues,i suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems :----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
Jan 18, 2012 | 1991 BMW 5 Series
1998 toyota rav 4 that keeps overheating. I just replaced the thermostat
Thermostat may be installed upside down...this can cause overheat.
To test your engine...if you don't think thermostat is faulty, remove the thermostat.
This is sometimes called "running cold"...and it should not overheat. If it does, you have bigger problem than thermostat.
You can test thermostat too by placing it in hot water thats not quite boiling and see if its opening properly.
Hope this helps...
Aug 28, 2011 | 1998 Toyota RAV4
My HP netbook keeps freezing. I don't know whether its due to overheating. But everytime when it freezes, its very hot. Another problem is, when i shut down my netbook, it always restarts by itself....
Hi xinyi pang17,
I have heard of this problem many times and it is usually due to overheating and motherboard problem. But first thing that you need to check is if the fan is working properly or not. You can use a canned air to blow out dust and accumulated particles from the fan.
However, freezing may also be caused by faulty processor. The unit may freeze (and overheat) while booting up, while using the computer or before the operating system loads if the processor is failing. To verify if the processor is failing, just access the BIOS (Basic Input/Output System) setup and test if it will overheat from there. If it does, surely the processor and/or motherboard needs to be replaced.
Hope this helps.
Jun 10, 2011 | HP Mini 1000 Netbook
Overheating and sometimes won't boot up
take care with your laptop,. check the fan rpm clean it and make sure everything ok
May 10, 2009 | Computers & Internet
A few problems
the lines are either a bad screen or a bad graphic card. overheating could be related because it does happen when the chip overheats.
Overheating
Basically every computer and laptop has a processor inside
That processor gets extremely hot when on however there
Is a heat sink with fan which cools it at all times.
Over the years dust builds up around the fan and heat sink
And blocks the air vents preventing cool air from coming
In and out. This causes the processor to overheat and
The reason why it’s shutting is because your laptop
Is doing so automatically to protect it.
To sort this out, you should switch off your pc or laptop
Remove the cover and access the heatsink and fan
It will need to be cleaned with a brush or an air-can
Properly and once this is done air should go in and
Out easily without overheating.
It is also recommended to add thermal paste
To the top of the processor however
You’ll need to remove the heat sink completely
For that. Making sure it is applies 100% back
On the processor.
Overheating is serious and must be taken care of
Asap. Here’s a link to a tool you can download and
Install to monitor your computers temperature
Download SpeedFan 4.37. free.
Mar 20, 2009 | Acer Aspire 9300 Notebook
Acer aspire 5610z
need more info....does it replicate without the battery? If it does, then it may be that the processor is overheating and shutting down the computer. Try to run with just the power adaptor and see if it happens. If it doesn't, then its probably the battery....
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Sometimes my computer restarts suddenly.
this problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Nov 29, 2008 | Intel D101GGC Motherboard
Intel D845GVSR Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
