Question about Toro Garden
I have a Model 20072 22 inch Toro Recycler Lawn Mower. I was mowing today and the mower just died. It wasn't out of gas, it just died. I tried a number of times to restart it, but it wouldn't start. It pulled free, but just made an odd clicking noise and would not fire.
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
mister_b_65
  • 74 Answers
SOURCE: toro mower recycler 22 inch will not start has
Is the plug actually sparking? To test this, first, unscrew the plug from the engine...then, with the wire attached to the plug, and with it laying on the deck, pull the engine over with the rope starter. If it doesn't spark, the plug needs to be replaced. The other possibility is that the kill switch is bad.
Posted on Dec 13, 2009
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Aug 15, 2016 | Toro Power Lawn Mower
How to fix stuck pull cord of a 22 inch Toro Recycler lawn mower
Is the engine seized?. Try turning the blade and if it won't turn then you have a seized engine. If that is ok your recoil has a stuck part possibly something has broken off inside. If it's an older model try shooting WD40 inside the recoil as it could be rusty.
Jul 25, 2014 | Toro Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
297 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
