Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Where can I order a pump repair kit for a dewalt d55151?
  • 285 Answers
You can find pretty much any part for the DW55151 at the following retailer:
http://www.ereplacementparts.com/dewalt-d55151-type-compressor-parts-c-1009_3079_3937.html
Posted on Jul 16, 2009
I have a D55151 Dewalt comp. that wont pump past 40lbs. What can couse this??
I don't what you mean by a "cold start" valve? Too much typing for a guess.
Dec 11, 2013 | Dewalt D55155 Emglo Air Compressor
Where is the oil drain for am78hc4v
There are four screws that hold the end cap on the pump. The fifth screw at the bottom, middle of the cap is the oil drain plug.
Mar 14, 2012 | Dewalt d55151 factory reconditioned emglo...
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
It is an electric motor Dewalt Emglo Compressor model#D55151. What type of oil should I use in it?
Dewalt recommends using synthetic pump oil, however if you only use the machine occasionally and not in a commercial setting, standard compressor oil will work great and save you money. Synthetic oil will last longer and can take much higher temperatures without breaking down. Lowes sell the kobalt brand of compressor oil and sells for about $3 for standard and $7 for synthetic. Home depot sells campbell hausfeld brand but equally as good. Auto parts stores also sell a line of compressor /pump oil just watch pricing for your needs. If you can't find compressor oil, non-detergent motor oil works just fine. Good holidays
Dec 15, 2010 | Dewalt d55151 factory reconditioned emglo...
Motor wants to start but won't then breaker goes out.
either motor start capacitor is bad, motor start switch ( which is inside motor) ,,,, or the motor is locked up, best advise is to have a motor repair shop look at it.
Feb 25, 2010 | Dewalt d55151 factory reconditioned emglo...
Sounds like a loud leaf blower, no engine sound.
You can get a rebuild kit from DeWalt for about $40 and fix it yourself. The flappers are most likely bent.
Jul 21, 2009 | Dewalt d55151 factory reconditioned emglo...
Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
EMGLO AM78HC4V pump oil
use sae 30 non detergent oil in this compressor let me know if you got any other qeustions
Jan 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
156 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
