Question about Mitsubishi WD-52525 52" Rear Projection HDTV
We had a power flicker and now the timer light is blinking fast. In the past, when this happened I would unplug the TV, wait 30 seconds, and plug it back in. The timer light would blink quickly for a minute and then stop, and everything would be fine. Today, nothing seems to make the timer light stop blinking, including a system reset.
  • 668 Answers
The Chassis Assy must be sent to Mitsubishi for them to refurbish. Most of the time it is caused by many Capacitors throughout several circuits have failed. It is not a repair to do yourself. If you call Mitsubishi at 1800-332-2119 they can refer a Service Facility to you. They will need to come out, remove the Chassis send it to Mitsubishi and install it when it is shipped back. It usually cost around 850.00 to 950.00 to get it done.
Hope this helps,
Skyassoc
Posted on Jul 16, 2009
Blinking power LED linksys
If the power light is blinking then you can try to reset the router.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Unplug the power and plug it back in. Wait for 30 seconds.
Check the status of power light on the router.
Jan 02, 2012 | Linksys Computers & Internet
Received this TV from a friend, was working when it left his house, I have place on tv stand, plugged it in, hit the power button, it came on for a breif second. Now the on-timer light is blinking, I can...
what was that outside temp in transport, was it in the cold. If so the unit needed to get back up to room temp before pluging in, if not you will blow the starter.
Mar 06, 2011 | JVC AV-32150 32" TV
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I WAS WATCHIN TV THE OTHER NIGHT AND ALL OF A SUDDEN THE TV TURNED ITSELF OFF AND THE LITTLE GREEN LIGHT IN FRONT STARTED FLASHING VERY FAST -SO I UNPLUGGED MY TV AND THEN PLUGGED IT BACK IN AND THE GREEN...
Some of these sets if you unplug them---The green power light will blink for about 70 seconds before it stops--this is normal as the receiver unit in this set is booting up. Wait for the light to stop blinking and then the set should turn on. Some of these sets develop a problem where the light never stops blinking--usually the receiver is now bad--very expensive to get fixed.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Fast Blinking Timer Light
If the timer light blinks at the same rate all the time...then the problem could be fairly serious (the tv won't start up). If the blinks are NOT consistent..then count them...it is an error code for service personnel. Try resetting the tv or plugging it out. Wait. Then plug it back in (resets the tv) and see what happens.
Jun 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
Tv does not turn on. Timer light blinks
Have you tried to hold the menu and input/device buttons on the front panel in together for 5 seconds to see if it will blink a two digit error code? Try that then let me know the code that the led blinked
Aug 05, 2008 | Mitsubishi WD-52528 52" Television
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
