Question about Hitachi 43UWX10B 43" Rear Projection Television
Blue and yellow go out of alingment
This creates an arc of colors and messes up the rest of pic. is it worth fixing or should i replace
  • 668 Answers
This has a Convergence Circuit problem.
It usually requires a pair of Convergence IC's
(STK392-110's, STK392-120's, or STK392-150's. Sometimes some low ohm resisters burn open when one or both of the IC's go bad. I would suggest that a professional do the work. Cost wise it would not be unusual for this type of repair to run 285.00 to 350.00.
The biggest thing to determine is if you want to spend this much. It is a good set just a little old.
Hope this helps,
skyassoc
Posted on Jul 16, 2009
    Problem Solver:
  • 16 Answers
It also happend to my projection tv. it is caused by prolonged use and overheating of the components inside. replace it
The color from our RTD258RV dvd player is green and yellow. Can anything be done or do we need to get a new unit??/
From your description, it sounds like the RED connection is not being made.
The colors are created using RED, GREEN, and BLUE (RGB) primary colors to create other colors. If any one of the connections is not made, the colors will be incorrect.
Check to make sure the RED connection is good, with no damage or breaks in the cable. If it appears to be good, it still may be worth replacing the cable, which is much cheaper than a new TV!
Jul 15, 2011 | Audio Players & Recorders
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
Green color gun shot
Bad convergence ICs. Much soldering. About $300 to fix by shop.
May 06, 2010 | Akai PT4298HD Rear Projection Television
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Blue Ghost from Defective Blue
this is the convergence IC's that are causing this and if you can replace them( unsoldering and soldering them ) then going to an electronic parts store to get your IC's for your set is what you will need to do , here is an example of the convergence IC's http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
if you need further assistance then just let me know and i will help
otherwise hope this info is at least worth a fixya
Dec 30, 2008 | Samsung HCM4216W 42" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Please help i need to reset the color
replace the convergence board about 100.00 for the board and you have to know what you are doing to remove the old one and put the new one in
Jun 23, 2008 | RCA P52926 52" Rear Projection Television
DVD monitor problem
no,but you can tap and see if color comes back, if not then replacing part in these units are not worth it, unless you just wanna know how it works and what fixes it, like I do
Aug 02, 2006 | Polaroid PDV-0700 Portable DVD Player
Hitachi 43UWX10B 43" Rear Projection Television Logo
152 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
