FixYa.com
Tags:
Panasonic KX-FL511 Plain Paper Laser Fax
DRUM REPLACEMENT CODE (by 3 users)
posted by bur-1 on Nov 18, 2007
DON'T HAVE OPERATORS MANUAL, NEED CODE FOR DRUM REPLACEMENT
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 02, 2008
change drum how to reset this option
Comment by kosxx, posted on Jun 17, 2008
The same problem i install twice a new drum an the error message still coming in fax screen...If any one know the reset code i will appreciate it
Solution #1
posted on Nov 18, 2007
Not Rated (0)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1375 votes
Download manual for you printer by clicking HERE
but I don't think there is reset code on these the new drum causes counter to reset when installed, did you install one?
Comment by Soulvisitor, posted on Dec 02, 2007
Thanks for rating!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Fax Machines problems?
Fax KX-F1810NL
Problem: Don't have a manual to... Answer This...
panasonic fax KX-FT73
i cannot use the fax machine it... Answer This...
Rod in gear box fell out
The rod in the gear box that... Answer This...
I want the manual for
I want the manual for the... Answer This...
error message CALL SERVICE 3
To: Anyone with ideas on help... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
