Question about Plumbing
806 series Georgetown bathtub faucet -- drips a
Price Pfister 806 series Georgetown bathtub faucet -- drips a couple of seconds after turned off -- hot or cold. Suggetions?
  • Anonymous Mar 13, 2014
    installed in 1988, a wall mount, has dripping problems
  • 297 Answers
This is the way most price pfister products work,it is not broken.no matter what you do you will end up with the same solution.don't spend any money on this project.
Posted on Jul 22, 2009
Pfister tub faucet is blocked
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets and knowledge of how these work.
Rod
US Parts Center
Jan 29, 2013 | Price Pfister Pfister 806-dy11 Treviso...
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
New Faucet drips for several seconds after it is
some of these new faucets are "soft off" which means the will drip or run for a second or 2 before the water stops. I know this can be annoying, but it is how some of them are made
Aug 01, 2010 | Price Pfister RT6-B0XX Georgetown Two...
I have a slow drip on my bathroom faucet. how do i repair it. p-f 8" w/separate hot & cold faucets
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
Feb 03, 2010 | Price Pfister Plumbing
I have a Price Pfister Traditional Chrome Roman Tub Faucet Model #WR2700C. It is a brand new faucet, just installed it. I'm getting a very slow drip from the faucet. What can I do to stope the leak...
There could be debris wedge in the cartridge of the faucet. If you have tried pulling the cartridge out to see, and you are still having these issues, more than likely it is a defective cartridge; in which case it should still be under warranty. If you haven't tried this, then I would recommend doing so. Just be sure to turn water off to your faucet first.
Nov 15, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Plumbing Logo
196 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
