Question about Akai LCT2716 27 in. LCD Television
Trouble shooting I can not adjust the contrast. Also there's a 4inch thick line running down the screen
    Problem Solver:
  • 12 Answers
If your screen is black with a horizontal line crossing it that means that your horizontal ic is bad,get it change and it will get back to normal.or if your screen is black with a vertical white line crossing it that means your frame ic is bad get it change.the problem is internal.and please dont put the tv ON again to avoid seriuos damage.
Posted on Feb 24, 2009
Line spool does not feed properly--thanks
could be incorrect cable used for replacement ( too thick)
could be wound on the wrong way looking at the spool the line is wound on anticlockwise
could be run out of line
read the user manual trouble shoot section
Feb 25, 2016 | Ryobi Garden
Lines on the screen
Hello
If the lines are thin and spreaded allover the screen from top to bottom, and are equally spaced around one inch of so apart, it will be a screen voltage rise problem. You just decrese both brightness, contrast and colour contols of your TV to zero position, and look into, where there is lines are visible on the screen or not. You should notice this in a drak room, so as to see is well, or close all the doors and windows to make the circumstance to a little bit dark.
If you can see these lines still, it is clear evidence of the above said fault. To rectify this fault you should open your TV. Open the back cover of the TV, and you will see a Line Output Transformer. It is otherwse known as LOT. It can be recoganiized easely as it its size. Normally it will look black in colour and a thick wire from it goes the picture tube's final anode, and look like it is stcked to it with the help of a rubber ******. Other two wires from it goes to the picture tube base board. These two wires are, one for focus and the other for screen.
There will be two controls on the lot, which can be varied, and seem to be integrated with LOT. Among, upper one is for focus adjustment, and lower one is for screen adjustment. Both will be marked as "Screen" and "Focus". You just find out the screen control. With the healp of a screw driver it can be adjusted.
Keep the TV on, Brightness, Contrast and colour to minimum, adjust this control to a little [ a very little movement should be done, otherwise the picture will be get blurred], to just eliminate the lines you see on the screen. Focus control and screen controls are interactable, that is adjusting one may effect the other. After eliminating these lines just up the brightness and contrast control to at about their mid position and press the menu button on the TV or remote control to get the menu screen. Look at the letterings, and if it seem to be out of focus only, just adjust the focus contorl to get well focused captions. The adjustments are hot, that is while the TV is operating. Take care. Ok.
Oct 26, 2010 | Mitsubishi CS-40503 TV
How do i adjust the contrast on the LCD screen?
You punch in Feature * 7. You can then adjust the contrast up or down. At my eye-line angle, I like it set at 2.
Cheers!
Apr 13, 2010 | Lands Phones
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Adjust screen Contrast
<Fn> +
Contrast up Increases the screen Contrast
<Fn> +
Contrast
down
Decreases the screen Contrast.
This will help you achieve this adjustment.
Feb 23, 2009 | Acer Aspire 3000 Notebook
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
While lines problem
There's nothing wrong with your camcorder. This sometimes occurs when there is a lot of contrast between the background and the subject or object you're shooting. Try shooting from a different angle or adjusting the lighting conditions.
Sep 06, 2005 | RCA CC-432 Camcorder
Akai LCT2716 27 in. LCD Television Logo
475 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
