I have lost the AC Adaptor and need a new one, the universal adaptors have out put voltage from 4V to 12V, what is correct setting. This is for a pair of Computer Speakers. The only marking on the bottom says "CN-04N567-48220-29F-06UW Made in China. I purchased these speakers for a Dell Laptop several years ago.
    Problem Solver:
  • 13 Answers
Buy better speakers before you start a fire.
thrift store, cheap!
Posted on Jul 16, 2009
My External HDD's adapter blow and i want to know if any 12v adapter will make it work?
Be careful, not all 12 Volt adaptors are the same. Some put out AC voltage and others DC. You need a 12 V DC adaptor. The adaptors are polralized, that is one output wire is + 12 V and the other is - 12V.. If you connect it backwards you can blow your hard drive.
If your not sure regarding correct polarity, consult a technician who knows how to use a voltmeter.
Also, the current rating of the replacement adaptor must be equal to or greater than the currenr rating of the original. Example: Old adaptor = 375 Ma. , New adaptor = 750 Ma. This would be OK.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 02, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Have durabrand portable DVD player with 7in TFT LCD Display. Code PVD-705U. Have losted the AC Adaptor. Is it possible to buy new Adaptor.JOE
Just take the voltages of that bad boy and the poloarity any universal adaptor will work just fine. Do notget cought up in the garbage that it will not. Radioshack is your good freind on this. You do not need a duraband AC adaptor you can use a universal one at best.
Thanks and please do leave postive feedback.
Jun 14, 2010 | Durabrand PDV-705 Portable DVD Player
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
I have a ns-15lcd and it won't turn on. I tried putting it a different outlet and nothing. When you put the ac adapter plug into the tv the red light comes on and then goes out. Any suggestions? Thanks,...
usuallly it is the adaptor that is bad yes with a load the adaptor will
produce the correct voltage but there is a capacitor that has gone south try to find a universal supply at Bestbuy with the same voltage and current output
Sep 24, 2009 | Insignia Televison & Video
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
Lost adaptor for LC-15B4M, want to run off 12V battery
Take the TV to radio shack they will fix you up with exactly what you need for cheap.
Sep 28, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
463 people viewed this question
 Grubhead
Grubhead
