Motorcycles Logo
ryanpilgrim187 Posted on Feb 25, 2016
Gio/Orion 125cc. Why is stock rear shock leaking oil?
I don't know how to add oil or weight of said oil all I see is a small twist off cap at the top. My weight is 190 pounds and I'm 6 feet tall so I already realize I'm big for this bike but do you think I need to upgrade my rear shock is this why I've only had the bike 6 months and it's already leaking oil
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Mar 30, 2009
SOURCE: Front Shock Absorber Oil Capacity
hi,
i conacted a friend of min that works on honda bikes he stated the fork is identical to the 250cc class rebel in diamenter and will hold aproximatley 4 to 4.5ounces fork oil. hope this helps and good luck!
goalie39
Ed
  • 479 Answers
  • Posted on Apr 13, 2009
SOURCE: oil in air line for rear shocks
on the left hand side of the passenger seat you will find a air valve, set the pressure to the desired setting as laid out in you operators manual
Anonymous
  • 11 Answers
  • Posted on Apr 23, 2009
SOURCE: Hard to select neutral
Difficulty in selecting neutral is most likely due to clutch drag. Does the bike jump forwards when you select first gear? This could be due to dry or wrongly adjusted clutch cable. Another though less likely cause could be weak clutch springs or a worn clutch basket. Aim for about 5mm free play at clutch lever.
Anonymous
  • 46 Answers
  • Posted on Sep 15, 2009
SOURCE: CRF450X Shock Rebuild Parts
it is not that common that you have to change blader and bushing...blader can be easily check out by looking if it is crack or to much warp...bushing will be ok if the coating is still there. i sugest that you bought after market race tech oil seal and dust...less expensive than honda and i only work with them and there is no issue yet. d'ont forget when you put oil into the shock you will have to wait to endclosed it till there is no air bubble at all in you're oil...thanks to leave good feedback.
Mike
  • 4383 Answers
  • Posted on Nov 14, 2010
SOURCE: right rear shock is leaking oil from top can this
Usually you just replace the shocks, as wear causes tolerances to go off, and leaks happen. Shocks are usually replaced in pairs.
Must facilities that dispose of non leaking small capacitors in a municipal landfill i.e., less than one pound PCBs of capacitor weight notify under Superfund?
Generally speaking, the density of mineral oil is 3.64 kilograms (8 pounds) per gallon and Askarel is 5.45 kilograms (12 pounds) per gallon.
2003 HD sportster - forks don't leak, bottoms out when front brakes applied
You may not have enough oil in the front forks or you may been a heavier viscosity of oil. I'm sorry but I don't have the oil capacity for your "Low Sportster". All I have is for "Hugger" models. They take 10.7oz. "wet" and 12.1 "dry". The difference between "wet" and "dry" is that if you simply drain and refill the front forks, it's call a "wet" oil change. If you disassemble and clean the forks of all oil inside, it's called a "dry" oil change. Contact the service department of your local shop and ask them how much oil goes in the front fork. To change the oil, there is usually a small screw in the trailing side of the lower fork slider down near the axle. Take these out and the oil will drain to a certain degree. Hold the brake while working the forks up and down with your weight to get all the oil that draining will get out of them. If you want all the oil out, you'll have to disassemble the fork tube. I would not do this if the seals are not leaking. Replace the screws in the sliders and then remove the top cap from one tube at the time and refill the tube with the specified amount of oil. Sometimes, the top caps can be difficult to get back in due to the pressure of the large spring in the front fork tubes. You may need a tool to compress the sping. I'm not sure on the "Low" model. I've always managed to the top caps back in without any special tool but I've never done a "Low" model bike. Harley uses what they call their "Type E" fork oil. I do not know what the viscosity of this oil is so I always use PJ-1 30 weight fork oil for most applications. Use only fork oil as any other oil may have a tendency to foam thereby negating any dampening action of the forks. If this doesn't solve your problem, you may want to check into changing the springs in the front forks. Progressive Suspension and others make kits for this.
Good Luck
Steve
2helpful
Kx250 rear shock is out of oil how do i add oil to it
If the bike is real bouncy with no dampining you need to have shock rebuilt you cant just add oil to fix.Most rear mono shocks have a little bottle of nitrogen gas on side of shock.When shock seals go bad the oil and gas leaks out. Most times it is cheaper to find shop to rebuild shock then buying new one.Mono shocks can run anywhere from 250.00 to 500.00$.you can get rebuilt for about 100.00 to 150.00$ depending on parts needed.
The rear shock on my et4 scooter is very tight and when riding at the moment it is very bouncy and the back end swings
Sounds like it has burst a seal and leaked all of its oil out, is there still oil ont he suspension leg? I had this last year on my Yamaha Fino, it's very dangerous to continue riding on it!
Loosen rear plastics on the suspension side. Fix the bike on its center stand to take the weight, the rear wheel will drop down.
Loosen the double nut at the top part of the shock. Once released, this makes it easier to get to the bottom bolts. Remove these, replace with a new shock.
Maybe go for a firmer spring/shock if you carry passengers. I've regularly got two on the bike so I went for a 230lb spring.
Hope this helps and vote for me please if it does.
7helpful
Yz125 rear shock amount of oil on
The volume is less than about 1/2 quart - it's usually not measured going in since you fill the shock completely - there's no need to measure. Some guys assemble the entire shock, then fill with oil and cycle the shaft, then install the bladder cap last. My method is to install the shaft and seal head and the bladder, then put about 2 PSI in the bladder, then bleed through the compression cap. My method is a bit more complicated to explain, but it's effective at eliminating ALL the air from the oil and it keeps the bladder from being installed in a collapsed state.
As far as the nitrogen charge - 145PSI is stock. 130-160PSI is typical.
H2 2005 oil leak on drivers side shock area.
im not that familiar with hummers but it sounds like youve found the end of the transmission vent hose or possibly the front differential vent hose and they will have seepage of oil sometimes. however if its a constant oil drippage, then there could be a buildup of pressure inside tranny or rearend. if u follow the hose down to its beginning youll know if its the trans. or differential(rearend). it might be normal to see this fluid,or it could be too much fluid inside trany/rear.
4helpful
What are the stock suspension settings for a 2003 Honda CR 250 R?
set your compression out 10 or 11 your rebound 9 or 10 and your fork oil height to roughtly 380cc.since its in 03 u should drain the fork oil out, u have to unscrew the top cap of the fork while its in the triple clamps( because its easier this way), loosen then take the fork out of the clamps, unscrew the top caps and pull the fork tube down and turn the fork upside down to drain the oil out then hang the forks up upside down for about 15 minutes then add the new oil right in the fork tube were you'll see a spring, just add the oil in there and you'll be fine and u should replace it with a good medium weight oil
5helpful
2answers
97 catera leveling light flashes all the time
The problem is a leaking air shock(s). My 1997 catera had this problem also. I drove the rear wheels up on a set of ramps and went underneath. There is a sensor located close to the rear axle's that moves up when the car is loaded in the rear. (luggage/person in the back seat). When the car senses the extra weight, a small compressor located up under the hood pumps air to the air shocks until the car is back level again. With the key turned on, and the engine off, You can actually move this sensor with your hand and after about 45 seconds, you will hear the small electric compressor come on and see the rear of the car rise. Even if the shock is leaking, the car will still rise but you can hear/feel the air leak on the rubber boot of the shock. The reason the light never stops flashing is because of the air leak the car never really reaches proper leveling. I know what your thinking, "I didn't have extra weight in the car"..doesn't matter car still levels itself from time to time without extra load in the rear. Possible road conditions etc. and also the fact your basically riding around with only one rear shock working like it should. hope this helps......dave
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
