Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All Pro Heater
I plug the heater in the power light comes on but no ignition
  • vhuss1 Nov 18, 2007
    I have a Dayton 3E218E that doesn't ignite. The coil gets red the motor comes on and kicks off after about 25 seconds.
  • nkawtg Jan 06, 2008
    Here goes......I have an All Pro forced air kerosene heater (20K BTU I think, can't remember exactly). Ran it for 8 minutes (total) when my air compressor kicked on (using the same outlet), blowing the heater fuse. All systems dead, of course. I replaced the fuse, now the heater begins to start (fan spools up, sounds like a jet engine starting), then before it comes "on line," it spools back down. Total time of operation is about 10 - 20 seconds. At that time, kerosene is dripping out the front of the "torpedo." I believe I am getting no spark, so my question is "Could the compressor surge have also taken out some component of the igniter before the fuse blew?" If so, any idea which component it could be (igniter, controller, etc.)? I intend to get into it, but want to be armed with some preliminary information, any help would be greatly appreciated!!
    Thanks, cold Michigan
I have 2 all pro kerosene heaters and neither one will start. The fans run have spark just no flame.
Posted on Nov 08, 2011
  • 625 Answers
Most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Posted on Nov 19, 2007
2 Suggested Answers
  • 181 Answers
SOURCE: Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Posted on Feb 23, 2009
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
I have an all pro 60,000 btu flex fuel heater. all pro went out business. i need a new igniter .... can anyone help me find this part ?
Try From the main page, click on kerosene heaters. Some igniters should be at the top of the page that comes up. See if one matches yours.
Jan 14, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
No heat
It is either the igniter or the limit. Their is a limit mounted
at the 12 o'clock position beside the igniter. If you look at this video you will see it. Well the base of it and 2 philliphead screws that hold it anyway. LOL
Check ot the video HERE
Jan 08, 2010 | All-Pro Propane Garage Shop Heaters - All...
How do I fix a FL4 code
A FL-4 error is an ignitor failure. There are three things that need to be checked to correct the issue. First is the ignitor. Replace if broken or burnt or cracked. Second is the 220/120 vac conversion plug that is plugged into the main board in the burner compartment behind the box cover. The black transistor may be burnt. Replace if burnt. This will happen often if the heater is connected with 220 vac power source. I highly recommend connecting to a 120 vac source if possible. The heater seems to like it more. But remember when switching power supplies to follow all manufacturers instructions on doing so. If after replacing these two items the FL-4 problem still occurs, the control board in which the conversion plug plugs into also may need replacement. This should correct the fl4 error.
Jan 05, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
My reedy heater pro 110 blows fuel out the front but does not ignite and then shuts down
The Pro 110 comes in 2 different technologies. The true model (examples: R110, RHD110T, etc) designates which technology your heater has. Rather than ask for clarification I am posting links to Troubleshooting Tips for BOTH types. You must investigate to see if your heater is the Spark Plug technology or the HSI (glowbar) technology.
Troubleshooting greatly differs between the 2 types.
Spark Plug Tips
HSI Tips
Nov 15, 2009 | Heating & Cooling
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
806 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
