Question about Sony DVP-SR200P DVD Player
My sony DVP-SR200P player has a disk in it and it won't open and keeps saying this operation not allowed or something like that. I have tried everything to get this dvd out
Try this. With the power off, press and hold the open button on the units face until it opens. This works with many Sony players and Sony recorders when there is an error. Hope this helps.
Posted on Jul 17, 2009
4 Suggested Answers
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
  • 21 Answers
SOURCE: All of the sudden our Sony DVP-sr200p dvd player
use soft cloth to clean the disc.
Examine the disc for any cracks or scratches that might be interfering with playback
Attempt to play another disc.
If another disc plays in the DVD player, then the previous disc is faulty.
If still the same. try to unplug for 3 hours. if the same. check sony.com/repair for service option
Posted on Oct 18, 2010
SOURCE: need region code for dvd player sony dvp-sr200p
unlocked dvd sony dvp sr200p code
Posted on Dec 18, 2010
Universal remote code for Sony dvp-sr200p using a rca remote
Use code search to find something hat handles some or all functions of your Sony DVD player. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Feb 19, 2017 | Sony DVP-SR200P DVD Player
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
All of the sudden our Sony DVP-sr200p dvd player is not loading our dvd's, it is stating "cannot read disk". Any solutions?
Oct 17, 2010 | Sony DVP-SR200P DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
I need to unlock the DVP-SR200P to play all regions.
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
Oct 09, 2009 | Sony DVP-SR200P DVD Player
Sony DVP-SR200P DVD Player Logo
538 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
