Question about Samsung HP-S5053 Television
Hp-s5053 samsung plasma with snow on hd content
Have a hp-s5053 samsung plasma where when playing hd content thru hdmi the bottome half of screen gets snow with picture any thoughts
standard def work fine no snow
  • dwagner466 Oct 08, 2010
    sorry a year later my buddy decided he now wants to fix this tv...there appears to be several "main boards" - x main (upper and lower), y main (upper and lower) and ASSY PCB MISC-MAIN;HP-S5053(Q7),D75A,BN4
  • 304 Answers
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Posted on Jul 16, 2009
    nwo a year later my buddy has decided he wants to fix this...there appear to be several main boards - x main (upper and lower), y main (upper and lower) and ASSY PCB MISC-MAIN;HP-S5053(Q7),D75A,BN4...any suggestions?? thanks in advance
    PS it is also a HPS-5053x/xaa if that helps out at all
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
How much will it cost for a cracked screen
I have a customer with a Samsung HP-S5053 in which the power supply has blown, and may have caused system wide component failures.
Rather than potentially spending a great deal of money trying to get his TV back to life, I'm certain he would be interested in either...
A: buying your TV for the good electronics
or
B: selling you his TV with a good screen.
Please let me know if you're interested in this type of deal.
You may contact me via email at sales@boiselcd.com. My name is Chris.
Oct 18, 2009 | Samsung HP-S5053 Television
Top half of screen going black.
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Feb 16, 2009 | Samsung HP-S5053 Television
50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Dec 01, 2008 | Samsung HP-S5053 Television
Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Jul 25, 2008 | Samsung HP-S5053 Television
Green and red pixel snow
you can adjust the V-scan voltages the adjustor is on the Y-main board, locate the test point and adjust down around 15 volt
Jul 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma TV picture problem
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
May 11, 2007 | Samsung HP-S5053 Television
Hp-s5053
you most have a bad conection problem, but thats a job to a tech ,dont do it your self or try to , this is a very delicate tv..good luck
Aug 06, 2006 | Samsung HP-S5053 Television
Televison & Video Logo
535 people viewed this question
Jerry Greenberg
Jerry Greenberg
