Question about Sony Playstation 3 (PS3) Console
Cant get a picture with a uk ps3 connected to a us
I am having problems getting a picture when I connect my uk PS3 to my tv out here in the US. The Ps3 is run froma transformer, so th evoltage and frequency are fine. I am not using an HDMI cable - would this make a difference?
  • 5 Answers
YES !YOU MUST CHANGED OUTPUT FROM HDMI TO AV- HOLD POWER BUTION UNTIL HEAR 2 BEEPS-CHECK INSTRUCTION PS3
Posted on Jul 16, 2009
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
Hi,made connection by use of HDMI cable from ps3 to tv with no problem.But now i wont to conect to tv which doesnt have aHDMI point.So i have got a SCART Lead which conect to ps3 to tv and i have an AV...
turn on your ps3 (with your tv also on) and hear the ps3 start power beep. after you hear this normal beep, press and hold the power button for 5 seconds till you hear a beep then let go of the button.
This will reset the outputs and resolution to defaults and you should get your display again, if you don't then the ps3 has a fault.
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Major problems with PS3 and viewing Bluray movies
did you uncheek the other options when choseing 1080p or it might be your receiver because you have to set that to make the picture quality as much as the ps3
May 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 60gb setup problem.
I have the same problem, I was told to buy a HDMI CABLE I did
but it still wont work
Dec 27, 2007 | Sony Playstation 3 (PS3) Console
PS3 - HDMI to SD change issues
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
