I just completed attaching a standard circuit to it and when I tested the outlet the reading indicated "open ground. It appears the inverter does not provide grounding. There is no provision on the unit for connecting to ground and there is no mention of grounding in the manual. I would appreciate any clarification anyone could provide regarding this. Thanks, Mike
The gfi circuit inside is bad or was used for something pulling too many amps. Most in verters only use a positive lead and ground lead to power the inverter. If you can run another ground to inverter case just in case im wrong about the inverter. But, if I am right the internal rectifier is not swiching ground paths and is not completing a path to transformer for 110 volts, because it was used improperly.
