Question about Hamilton Beach Water Cooler with Storage Cabinet
Water cooler overflows
A few minutes after I place a five gallon bottle of water on the cooler, it starts to leak. the leak comes out from all around the top of the cooler.
3 Suggested Answers
SOURCE: GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Posted on Jul 02, 2010
  • 14 Answers
SOURCE: advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Posted on Jul 10, 2008
What is wrong with a saturn sl1 indicator says it is hot after running for 5 minutes
John sounds like your sensor may be bad. Next it could be your thermostat sticking use a temp gun and measure the temp of your radiator at the cap. Do not remove cap. Just take temp. If it is getting hot it should spit water out. Check to see if the electric fan is coming on the sensor to cut the fan on maybe bad or the fan. Hope this helps.
Jun 09, 2014 | Saturn SL1 Cars & Trucks
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
My car starting over heating and i have put about one bottle of coolant and about five bottls of water its not leaking but the coolant level is still reading low and i dont know what to do and the coolant...
It has to be leaking some where if not on the outside then you have a bad head or intake gasket and the water is getting burned in the motor. Check all under the car for a leak if none found then the only place it can be going is in the motor. Do you notice a white smoke coming from your exhaust, if so that is water and coolant being burned. The coolant jar your refering too is the overflow and that is normal when it overheats. Used to be when it overheated it just shot steam out of the radiator cap, nowdays all that is captured and re used. Look around the water pump for an obvious signs of any leakage. might just be a bad pump and the engine is heating up and overflowing
Aug 20, 2011 | 1997 Lincoln Continental
We just bought a Beaumark water cooler and followed all the start up instructions and now after being on the third 5 gallon bottle of water there is still a taste on the water coming out of the machine is...
Have you tasted the water before it goes to the cooler to make sure it isn't the water. Use a cleanser in the cooler pipes and read the label!
Jun 29, 2017 | Dishwashers
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
Good luck.
leey05
Jan 07, 2010 | GE Refrigerators
1993 plymouth laser /talon/eclipse 1st gen dsm
If it's not over heating or at least leaking coolant in any way in 10 min of driving, then the water pump is most likely not the problem. It can't hurt to overfill coolant... the rest of the overfill will just leak out to the ground from an overflow tube.
When you say gallons... I hope you mean quarts. :)
No car to my knowledge takes 6 gallons.. that sounds like a train engine or something lol. Generally it's measured in quarts.. like smaller engines 6, and bigger engines are around 9.
I have an eagle talon which is an identical car to the laser... I think it's about 6-7 quarts if I remember right.
The sqeaky belt is most likely just a loose belt. I believe that getting any oil on the belt may cause squeaking for a short time.
Sep 22, 2008 | 1992 Eagle Talon
Advise
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
332 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
billconfused
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
