Question about Samsung YP-Z5 MP3 Player
My YP-Z5 unresponsive
My Samsung YP-Z5 is non-responsive. I turned it on the other day and it was on for a second and shut off...usually when I try to turn it back on at least I would get a low battery response or something. NADA...I can't even get it to come up on my PC when I try to plug it in to charge it. Any ideas?? I really miss my MP3 ;-(
  • Anonymous Nov 28, 2007
    I have exactly the same problem, was working fine until a few days ago when the screen just went black and now will not turn on or charge properly when plugged into my pc. Tried reseting it like suggested and still nothing, any other ideas???
  • Anonymous Dec 07, 2007
    My samsung will not turn on.One second it will turn on but either it cut back off or it have a low battery. I tried to hook it back up to the computer,but nothing happen. I use the reset button, but the screen is still blank. What can I do to fix it.
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Posted on Nov 22, 2007
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
YP-Z5
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Samsung YP-K3 MP3 Player
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
YP - Z5 MP3 player
have you tried waiting a few minutes after this appears? because if you turn it on for the first time, or you have turned it on after resetting it, it takes a few minuted to load. so if you wait a few minutes the main screen should come up.
Oct 15, 2007 | Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
153 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
