Question about Sony KP-46WT510 46" Rear Projection HDTV
Have a sony kp51ws520 sony tv. for a bout a week tv would take awhile to click on. got 9 blinking lights on stanby. everyone said g board found a g board and replaced it now tv won't turn on and get 3 blinking lights then nothing.
  • bullit25 Jul 16, 2009
    i know i have another problem what i'm trying to figure out is what the problem is. the g board is the power board replace it. now instead of nine blinks get 3 knew what nine blinks meant what does 3 blinks mean.
  • 601 Answers
Hi...
Three blinks means- B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Thanks
Smith
Posted on Jul 16, 2009
  • 4,234 Answers
The blinking standby lights are an internal diagnostic code. The 3 blinks usually indicate a problem in the power supply area. Since the problem changed with the new board, you may actually have a couple of problems. This is not a problem that is easily diagnosed remotely. If you have no experience repairing TVs, I would not suggest starting here.
Check the regulators on the power supply board, specifically looking for bad solder connections. Repair any of those that are found and update this with the results. I expect the behavior to change.
Thanks,
Dan
I just connected the main board A1727318A to Sony tv KDL-32XBR9
How many blinks do you have?
Main Power 2 Times (PS Board, G2CE Board)
DC Alert 3 Times (BM3 Board, G2CE Board)
T-Con 4 Times (T-CON Board)
HDMI 5 Times (BM3 Board)
Backlights 6 Times (Inverter Board)
Temp 7 Times (BM# Board)
HFR Error 8 Times (LCD Panel)
I hope that it will help you.
Apr 02, 2015 | Sony Televison & Video
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
I need a D board for a sony projection tv model KP-51WS520. Can I buy this anywhere or does it need repaired? Thanks in advance!
you probably will not find one available and they usually are repaired at com
SONY D BOARD 10 BLINKS REPAIR KIT KP51WS520 , KP57WS520 , KP46WT520
ponent level . but here is a link to the parts to do that with from EBAY
Oct 20, 2014 | Sony Televison & Video
I have a sony 52" rear projection tv red light
I will need the model number to assist if its the KP51WS520 the 9 blinks is zero cross diodes on the g board.
Aug 02, 2011 | Sony Televison & Video
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
Jan 17, 2011 | Sony KDL-46XBR2 Television
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
TV won't turn on
There's a small diode on the power supply board that causes this. Its identifiable by its purple stripe. You will need the correct type of diode to fix this properly. The diode supplies the standby voltage to the system control circuit, so when it fails, the TV will never come on.
michtech
Feb 12, 2009 | Sony KP-51WS520 51" Rear Projection...
Tv won,t come on now
i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
57 "SONY, DOES NOT TURN ON BUT STAND BY LIGHTS BLINKS 9X, THEN STARTS OVER
I dont think your unit has big problem.
1. 9X blinks means 9 VDC supply is shorted either in A or B board.
2. IC708 is faulty in A-board
3.PS701 or PS702 is opened in A-board.
Dont forget to Rate!
Good Luck
Dals123
Oct 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Aug 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
