My printer is making blank copies. It will not copy. It feeds the paper properly but the copies are blank. I replaced the toner but the copies are still blank.
see the cartridge do is good installed. Remove the cartridge and putt it again. If the problem do not go away please try with other cartridge. Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
how do you set printer to print in LTR instead of LTR-R. I need to turn LTR-R off? It is cutting off...
(More)
how do you set printer to print in LTR instead of LTR-R. I need to turn LTR-R off? It is cutting off part of my page, and the only paper options I have are auto, LRT-R, and Legal.
While doing 1 to 2 sided copying using the document feeder, machine jams up while paper is...
(More)
While doing 1 to 2 sided copying using the document feeder, machine jams up while paper is circulating through the machine in its copy cycle. Could the problem be jamming at the place where the paper is picked from the tray? What can be done to fix the problem?
