Question about Zebra Z4Mplus Label Printer
The display is not legible, can not read anything. is there a reset button to load default setting?
  • 4 Answers
Probably means that the board controlling the dispaly has gone bad. The only reset is in the menu so you would need to see the display or be able to connect the ZebraNet card if it has one attached.
Posted on Jul 28, 2009
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
Tablet wont stay on
Check the display settings and the power settings.
The display.
You can set for 5 minutes the default is usually 30 seconds.
The power settings.
Make sure it is not in savings mode an turns off the display very quickly.
Some battery savers reset the display.
Even other programs will reset things you had no idea.
Remember to read the information packet before loading apps.
Good luck these are the most common Tablet issues.
Apr 08, 2015 | Tablets & eReaders
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
How do I reset the amana PTH093B35AM to default settings?
you must read your instr. manual how to reset to default setting
go to www. fitness.manualsonline.com
God bless you
Oct 08, 2012 | Amana PTH093B35AM Thru-Wall/Window Air...
Hello. pls let me know how to restore my lexmark x6500 wifi printer??
To restore your Lexmark X6500 Series printer to its factory default settings, follow the steps below:
  1. Press the Settings button on the printer operator panel.
  2. Use the arrow keys to move through the selections until Defaults is displayed. Press the check mark button to accept this option.
  3. Use the arrow keys to move through the selections until Set Defaults is displayed. Press the check mark button to accept this option.
  4. Use the arrow keys to move through the selections until Use Factory is displayed. Press the check mark button to accept this option.
  5. Use the arrow keys to move to the required country, language, date & time, time format, fax number and fax name and press the check mark to confirm each selection.
  6. When the process is complete, the display will read Initial Setup Complete.
Source: How to Reset a Lexmark X6500 Series Printer to the Factory Defaults
To reset the printer's wireless network settings, please refer to this article: How to Reset the Network Settings on the X6570 Series AIO Inkjet Printer
Jul 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My env3 takes about 8 to 10 seconds to load the messages menu, and load anything in that menu (such as starting a new text or opening texts). anything to help it?
Please try resetting the phone but this will reset the phone to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Open the flip and press OK [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Press OK to select Revert. A confirmation message is displayed briefly before the phone resets itself.
http://www.resetcellphone.com/solution/LG/vx9200-env3
Feb 22, 2011 | LG enV3 VX9200 Cell Phone
Husband was in process of saving game on 360 when a 2nd tv was plugged into the 6-outlet plugin we have and knocked the cord unplugged to 360. When turned back on, it had lost all profiles for people and...
Hi angelia howe
Hi try this method and see if it helps
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Turn the console on. Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated.
  4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
  5. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console.
Please rate my answer if it was helpful cheers nikki
Jan 20, 2011 | Microsoft Xbox 360 Console
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Zebra Z4Mplus Label Printer Logo
171 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
