Question about Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Hooking up to antenna in rv
Can't find instruction manual, trying to hook up to antenna in rv and not getting any reception. We are near Clevland
  • 126 Answers
Try the site below: should be what you are looking for!
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL32XBR9
Posted on Jul 16, 2009
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
How do I hook an antenna to my tv
Hi Dwayne,
The Proton has an NTSC analog tuner and also an ATSC digital tuner. Have you tried switching or changing the SOURCE inputs?
You may also have to use the scan button to have the tuner "find" the channels for you once you determine that you have selected the correct source for the antenna.
See page 9 of the manual.
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=17#manual
Jan 18, 2015 | Protron PLTV-4250 42 in. LCD Television
Should I buy a new antenna wallplate for my rv? Current wallplate does not have an on/off switch mentioned by some bloggers. I wish to improve my reception.
Some HD antennas , in RV have a signal booster which enhances the signal . these may be the ones with the on and off switch. These run off either 12 or 120 volts. If replacing the head/ antenna buy one with a signal booster. It usually come with it's own switch or buy one for it at radio shack.
May 07, 2014 | Winegard RV7042 Wallplate/power Supply...
I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Apr 20, 2012 | Pioneer Audio Players & Recorders
Sanyo dcx686 am/fm amp receiver no fm reception
you should be able to hook up any am/fm antenna, like the new ones that come in a square and hook it up to the two left-most spots for a radio antenna, thats how i have mine. as for the manual, you can order them off of a site(if you can find a reputable one) if you search SanyoDCX686 on google. hope thats somewhat helpful =]
Dec 14, 2011 | GPS
Pioneer Avic D3 has poor fm reception when the car is on. It works fine when the car is off. Any ideas?
Your power antenna wire maybe hooked up to ignition. So when you turn off the car no more voltage is going to your antenna wire so your power antenna goes down causing a poor reception. You must hook up the blue wire on the radio harness to the power antenna wire.
Apr 10, 2010 | Pioneer AVIC-D3 Car DVD Player
I hooked an antenna up and can't get a picyure!
I assume you have tried to retune the TV & angle the antenna in different positions. Very often, due to the location of your home & the strength of signal in that area, you usually find that , no matter what you try, an indoor antenna is just not strong enough to pick up in a weak reception area. The only alternative is to try & add a signal booster onto it or much better still ( and a lot less future reception problems) is to rig up an outdoor antenna.
Sep 01, 2009 | JVC AV-32D305 32" TV
Changing to antenna
Firstly, depending which reception area you are in, an indoor antenna may not give you a good signal across all your channels. If in you put the antenna into the aerial connector of the TV & if in your set up menu, there is an Auto tune option then enter this & it will tune in all the channels it can find. If not then select the Manual tune option & you will need to tune each channel as you find them. Follow the on screen instructions as a guide.
Jul 01, 2009 | Televison & Video
When I hooked the DTA800 to my RV atenna
My understanding is that the Digital signal is weaker than the analog, so need a stronger antenna to pick up the digital signal, and MAY still not get any reception at all. Have you considered satellite for you RV? Won't need the converter at all then.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
On the converter box that we hooked up we are geting every channel except 5-1 5-2
Any -1, -2 channles considered as a off-air antenna channels. I assume you have the off-air antenna and good reception on it. So make sure your off air antenna hooked up to your receiver.
If everything is hooked up right and your reception on antenna is good, try to trace the line for your antenna. may find any visual problems such as loosen up, dog chewed the cable etc :D
Last thing if you don't find solution by yourself is call your service provider for service call.
Good luck
Oct 19, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Sony Bravia KDL-32XBR9 32 in. LCD HDTV Logo
319 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
