Question about Craftsman 25cc Gas Line Trimmer
Gas tank need new one - Craftsman 25cc Gas Line Trimmer
  • 2 more comments
  • chill76 Jul 16, 2009
    sears does not stock the gas tank anymore need one
    sears does not the gas tank need one.
  • josh1111 May 11, 2010
    i got gas but no tank
  • Kerry Degrand May 11, 2010
    go to sears parts direct.com and order it
My daughters rodeo wouldnt start. Battery is brand new, sounded like it wasnt getting gas. Fuel filter was just black, it has been changed. Truck still wont start. Any ideas?
check the tank is it plastic... if so drop the tank pour gas in bucket if black stuff in the gas take a water hose and spray it out wait till dry put it back on and put gas and try to start it,,, if fuel pump in tank replace it... please let me know how it turns out,,, good luck
Jan 28, 2012 | 1995 Isuzu Rodeo
Water mixed with gas
NEED TO ADD MORE NEW GAS POUR BOTTLES GAS TREATMENT IN FUEL TANK.IF TOO MUCH WATER IN FUEL TANK.BEST DRAIN OUT REMOVE MUCH GAS AS POSSIBLE OUT OF TANK ADD MORE NEW GAS ALSO REPLACE FUEL FILTER SEE WHAT HAPPENS.
Sep 06, 2011 | 1995 Jaguar XJ6
How do you get the gas tank out of a 1998 g20 van Van would not start, put new starter on it, but when it was cranked it sputtered and died. I thought it could be bad gas because it has not been moved in...
  • You need to start by removing almost all the remain fuel, fuel is very heavy
  • best method is to use a lift to get it off the ground, you could also use ramps to get the room need to drop the tank
  • disconnect the filler spout from the side of the van
  • disconnect the fuel lines
  • use lifting equipment to support the weight of the tank, make sure this is stable
  • carefully remove the tank straps and lower the tank, watch the fuel pump wiring and any other connection that may be in the way while lowering the tank.
Aug 10, 2010 | 1995 Chevrolet G20
I need to get the bad (old) gasoline out of the tank, but can't insert a hose into the tank to siphon it. How do I get the bad gas out?
How much bad gas?
If you have a half a tank or less put cup of paint thinner in the tank,fill it up w/good gas, you should be fine.
Make sure the thinner is in the tank first,or it will just lay on the top of your gas.
Now if you have a full tank of bad gas, do this:
On the passerger side underneath I believe there is a gas filterjust behind passenger front seat, Remove filter you need a new one,put a hose on the line, turn on ignition and pump it into a very large container,
replace filter, put new gas in
Jul 24, 2010 | 1998 Jeep Grand Cherokee
Disconnected intake hose from gas tank to primer bulb
is gas line broke or disconnected? Either way it has to be reinstalled.First, get new gas line, and be sure to get it longer then you need, because, you will need to cut a sharp angle on one end then install this end into gas tank, then reach thru gas cap opening with needle nose pliers, get ahold of fuel line and pull thru. if you do not cut angle on new fuel line, you will never get the line into gas tank.
Apr 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Need a new gas tank censar wht should i do
Most sensors are in the fuel tank. This should left to a repair shop since the fuel tank will have to be removed.
Nov 15, 2009 | 1997 Oldsmobile Bravada
1998 hyundai accent, i got bran new gas tank good gas pump good injectors puted on new gas filter this spring and my god dam gas pump/ filter will not top clugging up.. then my motor misses gas all i do is...
its a new tank before you fitted the tank it would need flushing. this is a lining they put on the inside to stop contamination, also to make sure its not been used, the same takes are on diesels and petrol engines and you don't want to mix them up so there is a film on the take to say its not used. you will need to flush out the tank. and flush your fuel lines injectors etc. when you bought the take they should of told you about the lining, or there should be a sticker on the tank to flush out before use.
Jul 04, 2017 | Hyundai Motor 1998 Accent
Gas line needs to go thru buttom of gas tank on sears weed wacker
Take your old line to a lawn mower parts store, ask for a new gas line of the same size. I would buy about a foot long. Push the line in the tank down into the tank(doing this with the tank empty), remove gas cap, turn upside down, a filter and your old line will fall out. Press the new gas line through the hole, push enough through that it comes out of the filler hole, place filter onto the new line, drop into tank, cut off excess and reattach to the carburator.
Aug 06, 2009 | Craftsman 25cc Gas Line Trimmer
Original gas tank replaced because of holes. New
It sounds like the new gas tanks do not have a breather fitted to them.
As you remove gas from the tank it needs to be replaced with air if not it creates a vacuum and natures way of filling a vacuum it to compress the space it is in
Fill a plastic soda bottle with fairly hot water , give it a minute then pour the water out and quickly screw the top on , watch the effect , that is your gas tank
There is either a metal or rubber tube or even a vent in the filler cap to allow air in
You did something to alter that ?
Jun 30, 2009 | 1998 Chevrolet K2500
91 Chevy Blazer gas tank needs cleaning.
the only thing i can help you with is the replacement. go to a big scrap yard, give them your measurements, and they will find a gas tank for you. my gas tank was about $100 and my friend put it in for free so i cant help you there.
Jun 24, 2009 | 1991 Chevrolet S-10 Blazer
Craftsman 25cc Gas Line Trimmer Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
