Question about Sony Cyber-shot DSC-W70 Digital Camera
Display screen is black
Have you been able to fix your camera yet? I have the identical situation with my camera.
    President:
  • 1,223 Answers
CCD FAILURE !
Just Call Sony they will do it FREE OF CHARGE ! ask them about BAD CCD !
it is a known manufac fault and all are doing it FREE !
Pls rate me WELL
Posted on Jul 16, 2009
Black screen on my canon S3 Si camera
This sounds like a common image sensor failure. Unfortunately Canon stopped fixing this problem over a year ago. Parts are NLA.
Feb 03, 2013 | Canon PowerShot S3 IS Digital Camera
Canot see subject trying to photograph
Hello, You should contact Canon about the situation. Let them know you are aware of the problem CCD sensor on the S1 camera. Actually S1 is repaired free of charge because of the CCD problem. You should suggest that your camera probably has the same defect as the S1. See what they say. If you need more info please advice. Arpi
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Nikon coolpix L100 screen just went blank and wont go on again
sounds like a bad sensor...... unfortunately this is a major issue... you are going to most likely have to send it to nikon to fix and it is usually most the cost of a new camera
Dec 02, 2012 | Cameras
Something has happened to my camera and now when i turn it on the screen is black and it says : Lens error , how do i fix it ?
From Nikon's website regarding this problem:
http://instrument-support.nikonusa.com/app/answers/detail/a_id/15978/~/lens-error-message
"Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
If the above tips do not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras."
Feb 28, 2011 | Nikon COOLPIX S70 Digital Camera
Screen is black will not take pictures
If screen is black you have 2 situations: camera is power on or power off. If its power on and screen is black, its very possible to have something defective inside on the cam microcomputer board or with the display block, and my suggestion is to get to a repair shop for a test or if you are still in the grace period from the manufacturer, to ask for a free investigation. Cheers (PS sometimes black screen occurs when the LCD inverter is gone)
Dec 09, 2010 | Canon PowerShot A400 Digital Camera
Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
May 27, 2009 | Canon PowerShot A550 Digital Camera
LCD Problems
Probably a canon repair situation
Apr 12, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Lcd screen does turn on
This is a defective CCD problem that is known to Canon. They will replace the defective part for FREE. Go here for more details: http://www.imaging-resource.com/badccds.html
Nov 10, 2006 | Canon PowerShot A75 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
