Question about LG Incite Cell Phone
Wi-Fi service available but LG Incite can't connect to it
The phone recognizes the availabe Wi-Fi networks but when attempting to connect it says ''connecting'' for a few seconds then reverts to ''available''. Also, if I am able to get connected via Wi-Fi, do I still use the browser icon to connect to the internet? In addition, I see references to entering valid web addresses or else the browser would say ''lost connection'' or something like that but where do I enter this valid address?
Thank you very much
  • LG Master
  • 928 Answers
A wifi connection reverting to available could mean a wrong password enter or a wrong encryption type.
If the available wifi networks are being use as hotspot, then you probably needs to register in order to use the wifi network.
If it's a private network, check if the network is at band 5 or 2.4. Just some tips for you to check out.
Posted on Jun 17, 2017
3 Suggested Answers
Tanker944
  • 12 Answers
SOURCE: LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Posted on Aug 05, 2009
SOURCE: My blackberry storm 2 browser is missing when i am
I had the same problem as yours. Here's how I solved it. First you'll need to download the blackberry software from sasktel website. Just google it and you'll find it. Once you've downloaded it here's what to do:
1. Download the latest firmware to your PC
2. Install the firmware onto your PC that is running BlackBerry Desktop Manager
3. Go to c:\Program Files\Common Files\Research In Motion\Apploader and delete the vendor.xml file. If you are using Desktop Manager 4.7 or higher you must also disconnect your PC from the internet.
4. Connect your device and open Desktop Manager
5. When prompted select "Upgrade Now" (If you are not prompted select Applications Loader > Update)
6. Follow the prompts and your device will be upgraded.
This solved my problem and my browser is running perfectly well on wifi.
Posted on Apr 02, 2010
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
My KC550 lg does nt run internet .I received settings also but it give s communication error.why?
First what is a KC550 lg , laptop , deskop , mobile phone.
Im assuming phone have you synced with the wireless router ?
Connecting your LG phone to wireless Internet is easy to accomplish with phones that can receive Wi-Fi signals.
You may decide to use the Wi-Fi capabilities in the event that you do not receive the best signal from your wireless provider at your home or office.
If this is the case, then hooking up to a Wi-Fi network near you could provide you with a faster connection to the Internet and a more reliable signal to send e-mails, texts and pictures.
Press the "Applications" tab on the home screen of your phone.
Scroll down the list of applications until you reach the "Settings" option.
Press "Settings" to bring up the menu.
Locate and click the "Wireless & Network" or "Connections" option within the "Settings" menu.
Select the "Wi-Fi Setting" or "Wireless Manager" option, then select the network that you want to connect to and click "OK."
All of the available wireless networks within your range will appear.
Enter the wireless network password (usually located bottom of router) if you are connecting to a secure network.
Press the "Done" button followed by the "Connect" button.
Jul 26, 2013 | Computers & Internet
I just bought a Lg optimus L7 l don't know how to
Wi-Fi network
1 Touch > Apps tab > Settings >
Wi-Fi from the WIRELESS & NETWORKS
2 Set Wi-Fi to ON to turn it on and start
scanning for available Wi-Fi networks.
Tap Wi-Fi menu again to see a list of
active and in-range Wi-Fi networks.
• Secured networks are indicated by a lock
icon.
4 Touch a network to connect to it.
• If the network is open, you are asked to
confirm that you want to connect to that
network by touching Connect.
• If the network is secured, you are
prompted to enter a password or
other credentials. (Ask your network
administrator for details)
Feb 03, 2013 | Cell Phones
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
To connect to a WLAN via Wi-Fi™:
  1. From the Home screen, find and tap Settings.
  2. Tap Wireless controls > Wi-Fi settings.
  3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
  4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
Useful tip:
  • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
  • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
  • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
  • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
You can also try updating your softwares by going to the sites below;
Update Service,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
PC Companion,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
Start the program and just follow the on-screen instructions.
I hope this will help.
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
  3. Choose Done.
  5. Choose Next.
  7. Choose Next.
  10. Choose Finish.
Aug 05, 2009 | LG Incite Cell Phone
LG Incite  Cell Phone Logo
219 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
