Question about Dell Inspiron 1501 Notebook
I just got a webcam and my laptop overheats what
I just got a webcam and my laptop overheats then shuts off. what should i do?
    Problem Solver:
  • 13 Answers
You need to buy a laptop cooling fan. Not expensive. This is a must so you don't burn out the components on the laptop or oops! laptop no more....
Posted on Jul 16, 2009
HP Pavillion tx2-135dx laptop overheats
hi.Fan Always Runs Or Laptop Overheats And Shuts Itself Off
Warning! Before Disassembling Laptop always unplug power and remove the battery.
Laptops that shut down without warning are often experiencing overheating issues. Overheating may be a symptom of age, of clogged ventilation or impending failure, but it can also result from simply using the laptop in a bad location. Before you try to take the laptop apart to look for problems, it pays to patiently troubleshoot the symptoms and see if an easy fix is possible. I wrote The Laptop Repair Workbook to teach basic laptop technology and troubleshooting to regular people and techs in training. The overheating flowchart below is one of twelve flowcharts in the book.wfwmoavismn7iaaaaasuvork5cyii=
May 09, 2014 | HP Pavilion Computers & Internet
Charging port repair
there may be two problems...
1.) your charger may be too old, So first check your charger, on another laptop. If you don't have another laptop of same cord.Then replaced your charger from new one...
2.) you laptop may be too old or you use it very roughly. by this charger area get dusted. So you need to just clean your laptop internally. And especially from the cord area portion of the laptop.
Jun 11, 2013 | MSI S6000 WITH INTEL CORE I5-450M 2.4GHZ,...
Logitech QuickCam Deluxe for Notebooks webcam immediatelly shuts down my Compaq laptop as soon as it's plugged into the USB port.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 26, 2013 | Logitech QuickCam Deluxe for Notebooks
Overheat?
No. Sounds like too much voltage. Check adapter voltage & compare to Webcam Voltage.
Sep 16, 2012 | Airlink 101 awcn200 usb 2.0 webcam with 6...
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
Laptop Overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 16, 2012 | Computers & Internet
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Gateway 7320GZ Notebook
HP compaq nx6125 windows vista 64 bit
http://www.daileyint.com/hmdpc/overheat.htm
This site has a some info on that.
I must say that all laptops get hot but the shutting off is worrisome. Try placing it on a raised surface that does not block the air vents and have a fan or something to circulate some cool air around it.
Mar 30, 2010 | HP Compaq nx6125 Notebook
Laptop Compaq Presario F 700 overheats easily and shuts down
When the CPU overheats it shuts down (ie thermal overload) and won't startup until it has cooled down. This problem is caused by faulty fans (with bearing problems and may not spinning at normal speed) or the fan and heatsink assembly is clogged with dust.
Check the vents and fan and vacuum and remove the dust.
If the laptop is not placed on a flat surface there may not be enought air entering the vent on the bottom of the laptop.
To improve ventillation, you can stick rubber pads on the bottom of the laptop to increase the height of the laptop off the table. Better still purchase a laptop fan assisted base and place the laptop on this base, this provides further fan assisted ventillation.
Aug 26, 2009 | Compaq Presario 700 470024-192 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Dell Inspiron 1501 Notebook Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
