Question about White Sewing 1730 Mechanical Sewing Machine
I am trying to repair this machine it had a broken gear that changes the stitch from straight to zig zag and i can not find the part to fix it with i hope that you could help me find it thanks
  • 374 Answers
well,there is a lot of mechanical link to be dismantle before you can disconnect the gear from the shafting,and replace beside the timing order when connect the mechanical link,you can rely on www.SewingMachineRepair.com and check how it can help you.best regard
Posted on Jul 16, 2009
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
  • 980 Answers
SOURCE: how do you set the zig zag stitch on a Jones
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
Posted on Sep 11, 2009
SOURCE: My neighbor has a Kenmore 5180 machine that is
how do i insert the needle into the sewing machine
Posted on Oct 22, 2009
RickE1
  • 202 Answers
SOURCE: Zig Zag wheel not working
Need to know what type of machine, but most likely the connecting arm for the zigzag width to the needlebar is gunked up somewhere. Clean the joints of it and oil liberally with lots of exersizing it.
Posted on Mar 18, 2010
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Stitch selection does not work
The switch could be bad or the mechanics that physically move the needle for the zig zag could be broken/worn. Hope you get it fixed soon!
Apr 04, 2012 | Sewing Machines
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
Dressmaker zig zag deluxe s3000 doesnt pick up bobbin thread
it's possible that a gear is broken or worn a sewing machine shop can tell you exactly
Feb 20, 2012 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Only does zig zag stitches, no straight stitches,
Jul 26, 2009 | Necchi Sewing Machines
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
White Sewing 1730 Mechanical Sewing Machine Logo
57 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
