Question about Electrolux Epic 6500 Vacuum
Cord has been hyper extended, will not retract
Cord issue
  • 97 Answers
Try pulling the cord a little, while holding down the cord release button. if nothing happends and it doesn't retract, suggest taking to a service center or your local vac shop for repairs.
Posted on Jul 20, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Cord retraction help
if you can open it up extend the cord and wrap it around the spool.make sure its clean.spray a little wd40 on the shaft of the pully so it moves freely
Apr 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Dec 18, 2008 | Electrolux UltraLux 2000 Bagged Canister...
It sounds like the rewinder spring either came off the retainer or broke. If it broke it must be replaced. If it just came off, it can be put back on and rewound. It is a LONG flat piece if springsteel which is VERY sharp. Be Careful.
Dec 17, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Vacuums Logo
445 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
