Question about Kitchen Ranges
No power on kenmore range
My range was working this morning and now, no power at all. not clock, gas top, oven light, nothing. any idea?
  • 6,784 Answers
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Posted on Jul 16, 2009
  • 61 Answers
CK THE BRAKER OUT SIDE THE HOUSE BY MEEDER IS A BIG BRAKER OR 2 BRAKER MY HAVE A 40 OR 50 ON THEM
Clock,timer and oven does not work on Kenmore gas Range
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
Oct 04, 2007 | Kitchen Ranges
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
Clock and lights work but cook top and oven do
The clock and the lights run off of 120 volts and the heating elements work off of 240 volts.
It would be safe to say that one leg of the power is missing. Try turning the circuit breaker off then back on fully.
If this does not solve the problem then you will need an electrician to check the plug behind the range or the 'L2' in the range.
Apr 26, 2010 | Bosch HGS435UC Gas Kitchen Range
Kenmore 790 issue
Since you mentioned replacing a heating coil, I'm assuming this to be an ELECTRIC RANGE vice a gas range.
It sounds like you may be missing part of the input voltage at the wall receptacle. You should be reading 220-240VAC across the two hot terminals (left and right slots). Some homes are wired with two separate breakers to make up the 220 service that feeds your appliance. If this is the case, make sure one of the breakers is not tripped.
Or, you may have a possible bad power cord. With the unit unplugged, check the continuity of the power cord from end to end to make sure the wires are not broken.
The clock assembly functions off of a 110-120VAC source which is tapped off the input voltage. All the elements all use 220. If one of the input legs is missing, the clock will still function, but none of the elements will work. Please check and get back to me if this isn't the problem. I hope this helps you.
Dec 29, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Kitchen Ranges Logo
382 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
