My menu keeps popping up tv and my volume dont work
My menu keeps popping up on my tv and my volume button wont work
  • 668 Answers
Most of the time this is caused by one or more of the front panel buttons being bad. I would have all of them replaced.
Posted on Jul 16, 2009
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
Mar 23, 2011 | LG W2284F 22" 2ms LCD Monitor - Black LCD...
Captions are on ther tv and i cant get into the menu. A message keeps popping up saying blog. fpa escend and i dont know what to do please help
Hello
Just reset your RCA tv by the following method. After reset you have to enter a new parential code and proceed.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the [0] button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Feb 23, 2011 | RCA TruFlat 27F520T 27" TV
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Dec 23, 2009 | HP 22" Widescreen Flat Panel TFT LCD HD...
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Nov 17, 2008 | RCA F32650 32" TV
Television
You need to check what micro switch are bad and replace him because for that the remote don´´t work
Aug 25, 2008 | Televison & Video
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
