Question about Frigidaire Affinity ATF7000E Front Load Washer
Error E10 means what , on the screen shows this error in any cicle you use to watch
  • 61 Answers
I;M NOT 100 % I THING IS A CODE FOR BORD TRY TO UNPLUG THE WASHER FOR 2 MINT AND PLUG BACK IF IT DON;T STAR YOU WILL NEED A TECH. TO GO OUT AND CK FOR HOMS AND MOTOR AND ON BORD.
Posted on Jul 16, 2009
Error E10 keeps popping up and washer stops 2 or 3 times during cycle and have to reset it
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire ATF6000ESO washing machine that keeps showing and E10 error code. It doesn't seem to be finishing the spin cycle. can you tell me what this code means?
Often the cause of this error is that no cold water is getting through the cold water valve (inside the machine). OK, there may be a loose wire to the valve, the valve may be stuck, or faulty. It may be able to be freed up if stuck, but it's simpler and easier to just replace it with a new one.
Below is your service and repair manual to download.
http://frigidaireservicetips.com/pdfs/489_5.pdf
Sep 23, 2010 | Frigidaire ATF6000ES Front Load Washer
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Wash starts, then stops postin E10 and now soap does not dispense
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
My washer is showing a code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer - e10 and water hose shaking
Sep 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Error code e10 and ef0
Aug 12, 2008 | Frigidaire Washing Machines
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
