Question about Garden
The pull rope on my Toro push mower broke. It has an automatic rewind. How do I replace the rope?
  • 154 Answers
Remove the top of the housing and repl rope, its pretty easy
Posted on Aug 05, 2009
Kholer engine engine repair
remove starter houseing cut old rope out then rewind it till it stops slip new rope through houseing hole and pull hole put a screw driver threw houseing and pulley to make it so it cannot unwind then not the pulley end of rope take a lighter heat knot this will make sure it will not unknot hold rope pull out screw driver pull rope until knott is seat to pully slowly let cord rewind cord until it stops pull out two tune of pully install handle put knot in it and heat the knot with a lighter done cut excess cord off reinstall the red neck let me no if you get have problem like motor dont star or is hard to start
Aug 28, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
The starter rope broke on my Toro mower and the housing around it is riveted on. how do i get it off to replace the rope?
I cannot believe that someone suggested grinding off the rivets. If the bottom portion of the rivet falls down and gets caught by the magnet on your flywheel and you try to start it you are going to do some SERIOUS damage.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank2.gif to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Sep 15, 2009 | Toro Lawn Mower With Toro Power Tools
Pull string broke on crafstman 6.75 mower
when the rope broke you first must rewind sring and load tension on it first then install spring while it is underload clamp with vise grips until string is fed through then release slowly allowing string to recoil
Jul 15, 2009 | Toro Lawn Mower With Toro Power Tools
How do I fix the pull rope on a push mower?
Did the rope break, or is it hung up? if it broke, you need to take off recoil cover and manually rewind spring until existing rope can be pulled through the cover to compress spring. use the same size of rope and feed new rope through hole with spring about fully wound. If hung up, you need to clean the cover that is on of the crank case top. Do not use oil because it will make the ball bearings seize up. is it a briggs or other? I explained procedures for a briggs.
Jun 21, 2009 | Garden
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
