Question about Canon PIXMA MP530 All-In-One InkJet Printer
No power I have a MP 530, I changed the ink cartages and O no power no lights. Checked AC connection tried different outlet HELP.
  • 1 more comment
  • albertnet Nov 14, 2008
    hi, I have the same problem here, I checked the ac adapter and its supposed to give various output values (32v, 24v, 16v & 24v), and all the readings are way under its value, does anyone know the part number of this ac adapter? I googled every single number on the plastic cover with no avail, also, Does anybody have the schematic of this part?, I could fix it but I wouldn't like to de-solder every component to check it. Thanks in advance.
  • butler3825 Mar 23, 2009
    No Power to MP530. On button doesn't work, all of a sudden. Plugged into different outlets, etc. No good. Any suggestions?
  • jopinion52 May 14, 2009
    no power. power supply checked out ok.
  • Canon Master
  • 1,113 Answers
Power supply or main board, no cheap fix, Replace it if not under warranty (1year)
Posted on Nov 18, 2007
  • Soulvisitor
    Soulvisitor Dec 02, 2007
    Thanks for rating!
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
Feb 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I have replaced the ink cartidges and keep getting an alarm saying check ink It will not allow me to print or do any kind of diagnostic function to fix this on our MP 530 printer please help
Hi there it is ink error.
Clean the cartridges
Allso gave it a go may work
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
But some time when you get the chance do clean the waste tank out.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Problem with refill in for my Canon Pixma MP-180
Hi there
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Feb 06, 2010 | Canon PIXMA MP180 All-In-One InkJet...
No sound comes out of my speakers and the on light no longer works...but you can listen to music through headphones. can anyone help?
first check the power supply for the speakers/try in different power outlets/check the sound options in control panel
May 14, 2009 | Logitech X-530 Computer Speakers
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
Waste ink absorber
Try this:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The
indicator should be orange.
6: Press Power to set data.
Hope that helps.......
Aug 04, 2008 | Canon PIXMA iP1600 Printer
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
332 people viewed this question
old marine
old marine
