Cars & Trucks Logo
David Liccardello Posted on Feb 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ford 1100 tractor diesel 5 port ignition switch with glow plug git a new one need help wiring it what cable go were Need a diagram if possible
misterpj2u
Level 2:
Scholar:
New Friend:
  • Expert 65 Answers
  • Posted on Jun 06, 2016
misterpj2u
Expert
Level 2:
Scholar:
New Friend:
Answers
65
Questions
0
Helped
50970
Points
131
Are the glow plugs single or dual wire if they are twin or dual wire one wire is positive and one is negative. I will base this on twin wire
I hope it is a negative earth system as I won't bother with positive earth instructions at this stage.
Get a multi-meter that has alligator clips on the cables attach black to a good ground then with the solenoid power wire removed on the starter (so it wont crank) get someone to hold the ignition switch in the on position, then test each pair of wires one will show voltage this is the positive one (mark each positive wire) now release the starter switch and change the multi-meter to ohms test the wires that did not show as active they should show good low resistance (hopefully 0) connection. now you can reinstall the glow plugs making sure positive on the glow plugs is paired with active positive wires that were marked then attach ground wires to the glow plugs.
Reattach the solenoid power wire and try starting it
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Nov 23, 2008
SOURCE: ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Anonymous
  • 82 Answers
  • Posted on May 08, 2009
SOURCE: 87 regal ignition switch wiring diagram
Thick wires at IGN SW .... Red(s) - supply power from the battery to the IGN switch ... Pink - ignition supply ... Orange - Accessory power ... Purple most RWD sometimes (Yellow most FWD) - Starter .. Did I miss any? It's been a while The thin wires on the IGN swich are for key sense and VATS (if applicable)
cy schousboe
  • 2002 Answers
  • Posted on Oct 18, 2009
SOURCE: need wiring diagram for 1990 ford f-250 4x4
If you are looking for a complete wiring harness diagram then faxonautoliterature has the original Ford service manual for your truck which has complete diagrams in it. If you are looking for components to check then Haynes Diesel Engine Repair Manual, part # 10330 has good diagrams of components and terminals pinpointed for testing purposes as well as the specs for those tests and a good diagnostic section. Hope this helps.
cy schousboe
  • 2002 Answers
  • Posted on Feb 07, 2010
SOURCE: need spark plug wiring diagram for 1965 ford
Try this. If the distributor is in the right way, the clips that hold the cap on should be just a hair off of 12 o'clock and 6 o'clock. #1 is positioned at 1 o'clock, which is at the firewall side of the distributor. The firing order is 1-5-4-2-6-3-7-8and is counterclockwise from #1. The passenger's side is cylinders 1-2-3-4, from the front of the car. The driver's side is 5-6-7-8 from the front. Hope this will help.
Anonymous
  • 24 Answers
  • Posted on Sep 12, 2010
SOURCE: need a wiring diagram for
Here it is. Please vote for me and give me a high rating, thank you. It takes time to find these things and I'm giving it to you free. Thanks and good luck.95e7514.gif
Testimonial: "very helpful and nice "
I'm needing a wiring diagram for a 4630 Ford Diesel tractor, where can i go for this.
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/26030588-oopj3rvil2bxeij5wngtepgw-5-0.jpg
http://www.fixya.com/support/t26030588-get_wiring_diagram_4630_ford_tractor
http://tk.twafkot.schmiereimweb.de/guide/ford-4630-tractor-wiring-diagram.html
http://www.google.com Search terms:
1helpful
2answers
Do you have a wiring schematic for the starting system on a 1994 Ford 4630 Diesel Tractor?
Randy, Check the attached link and scroll through it, hope it has the info. you need.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 Ford 4630 Diesel Tractor wiring schematic for the starting system...
1helpful
Have two wires for glow plug for a cole hersee ignition switch for diesel were do they go on back of ignition switch
You may need a different type of switch to operate the glow plugs. This is a general diagram of the type of switch needed
1helpful
Starting issue, I have a 1993 ford f250 7.3l pre powerstroke. I started the motor and it stalled out like there was a short, now when i turn the key my glow plugs do not fire and wait to start doesnt show...
On some Models the glow plug Relay does not have an integrated Power Relay. This means there is a second Relay before the glow plug Relay that feeds it power.
You should check the wires running to the glow plug Relay for power with the key ON. Check some other wires off of the Ignition switch to make sure your 20 year old Ignition switch is good.
There are some sites which show vehicle wiring. Autozone has a free section after Registering your vehicle but it takes a little sorting through the Help section. There should be a fuse to protect the above Relays.
Make sure you find the Diesel-equipped wiring circuit. Diesel ignitions are different from gas units.
3answers
Expert van 2lhdi 2005 very poor starting in cold weather had glow plugs and relay fitted still no better. i only do 3000 a year and mainly short jouneys less the 5 miles. new battery last year. it does...
Firstly fit a manual overide to the heater plugs .relay -push button type switch -wire -connectors ,run a wire direct from battery to relay ,other side to heater plug relay output so it feeds all the heaters ,push button inside cab with a 12v feed from ignition switch running to relay then other side of relay to earth ,leave vehicle on charge often on trickle charge where possible ,also on a full tank of diesel put in a litre of petrol to stop diesel waxing up ,nice old rug or blanket over engine and it will first time every time ,only use the petrol when weather below minus 5c though ,great vehicles these peugeots but i do like my ford transit
I have a 2003 gmc sierra duramax diesel and im in need of a glow plug diagram?
The diagram is simple each glow plug is connected in a series circuit like this -0-0-0-0-0-0-0 that's a in-line 6 for a V-8 it would look like this
[-0-0-0-0
[-0-0-0-0
and the plugs would be hooked up on the back then if you follow the wire to the glow plug relay you will find that the relay has four wires one to battery one to the glow plugs one to the ignition switch and one to ground in the box. If you want you can purchase a manual for 5.99 on-line. and it covers the three fuse-able links for this system and the new Glow plugs available for this truck here is the web page. http://www.wiring-diagram.com/?gclid=CMuAvJ3Ql58CFQZfagod0jpAxQ
Glow plugs
glow plug wire harness under valve covers often deteriorates causing no glow plug heating. The connectors and wire terminals are available from Ford as a kit or individually. Do not replace the harness. $600!
Still need the fuse panel circuit? Look in owner manual.
glow plugs use a relay too.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
