Question about Craftsman Garden
I have a craftsman 917.377504 and the motor won't turn over. Has oil and gas, but it won't start.
  • Lesa Chesebro Jul 16, 2009
    We replaced the spark plug - does that answer your first part? No idea on how fresh the gas is.
  • Mike McDowell May 11, 2010
    Does it have spark? How fresh is the gas?
    New Friend:
  • 93 Answers
Check Flywheel Key
Posted on Sep 15, 2009
I have a 15.5hp Craftsman riding mower with a 42inch cut I keep getting gasoline under the OHV valve cover and in the oil pan !!!!! The motor won't turn over !!!!!! I adjusted the valves and it started...
Needle valve and seat is the first place I would look. Sounds as though your needle valve is sticking in the carb. Since the needle valve and seat is the only way gas enters your engine, it fills the carb bowl, then because it's sticking/leaking, gas starts running into the engine.
Look for trash in the bowl when you remove the bowl. Shut off/drain the gas then pull the fuel line to the carb, pull the carb and spray some cleaner into the fuel inlet after you remove the float and needle valve.
Sep 29, 2017 | Craftsman Garden
My craftsman 32cc leaf blower won't stay running
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
My aircompressor is a little older and it is a 240 volt. Everytime I plug it in it turns on for about 10 seconds then shuts itself off. And then it won't turn back on until I unplug it. Outlet is...
This is usually a sign that the motor capacitor is bad.. and then it trips the overload...first thing to do is to replace the motor capacitor with a new one of identical rating...
heatman101
Sep 06, 2011 | Craftsman 33 gal Air Compressor 6 hp...
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
Craftsman rider dlt 3000 throwinng gas out muffler won't start can anyone help.
Turn off fuel and do not try to start because it can shear flywheel key or catch fire.It sounds as if the float needle is not seating {closing}properly and must be cleaned or needle/seat replaced.Check to see if fuel has raised oil level on dipstick,if so you must change oil as well as the oil filter.
Nov 16, 2009 | Craftsman Garden
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Starting motor ok, but sounds liKE starter bad!!
Hello beadingblond:
>>Check the Valve Clearances. If the Valve Clearances are Not Correct the Compression Release Does Not Operate as Designed and the Starter will seem to be Dragging.
>>Also, Is the Crankcase Oil Overfilled and Contaminated with Gas?
Respectfully
John
Apr 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
