Question about Denon AVR-687
How to change the video output on denon avr 486-I have 3 devices using the component video inputs (playstation 2, xbox 360 and a dvd player) but i have an analog video output going to my tv. my devices are set to output component video, but i thought that it would automatically downconvert abck to analog. can i change the video output back to analog video on the receiver or do i need to change the video output from the devices?
  • Anonymous Mar 28, 2014
    All of my HDMI input is working perfectly, while my Analog inputs AV1- VAUX does not have a video output to an HDMI Connection
  • 441 Answers
Under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Posted on Jul 16, 2009
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Changing the component input to composite or s-video output
It will not work. This unit can not convert video signal from component to s-video. Use the same type of connections on DVD and TV.
Apr 11, 2009 | Denon AVR-4802 Receiver
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
Dec 31, 2007 | Denon AVR588 Receiver
Denon AVR-687 Logo
357 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
