Question about GE (PSS26MSRSS) Side by Side Refrigerator
Need to replace fan on GE Arctica. Do I need to remove the Fan Schroud? How do I remove the Schroud? One of the two screws is impossible to reach and remove>
  • 61 Answers
B4 YOU DO THIS ARE YOU SURE THIS IS THE PROBLE ON SOME OF THE REF. THE BORD IN BACK WILL GO OUT AND DON;T SENT POWER TO THE MOTER 1ST CK FOR VOLT. THE CONDERSER FAN YOU WILL GET 120 VOLT AND THE INSIDE 80 TO 120 DEPAND ON SPEED. IF YOU NEED TO REPLACE THE EVA. MOTOR IS NOT HARS TAKE SHELF OUT TAKE INER BACK COVER OUT TAKE THE TO SCRUE ON FAN COVER PULL OUT AND THEY ARE 2 MORE SCRUS ON BACK. GOOD LUCK
Posted on Jul 16, 2009
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Does the fan and fan schroud need to come off to replace the radiator
Yes,
Hold the fan clutch steady with a fan clutch wrench and disconnect the fan using a fan hub wrench. Notice the fan remains held in the engine compartment by the fan shroud...
Remove the two bolts securing the fan shroud to the radiator, with a ratchet and socket. Pull the fan shroud and fan blade assembly from the engine compartment.
Jul 21, 2011 | 1997 Mercury Mountaineer
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
How to remove the fan clutch
To remove fan clutch, you need a special clutch fan tool. Sometimes i can remove it with a large adjustable wrench while locking the water pump pulley. Remember to turn counter-clockwise.
Feb 18, 2011 | 1996 Ford Explorer
Need to replace water pump. how easy it it?
Pretty easy. Just drain antifreeze. Then loosen 4 bolts that holds fan to pulley. Remove plastic fan schroud and fan pulley. Loosen water pump bolts in criss cross pattern and remove water pump. Clean surface install new gasket and water pump install in reverse order. Tighten in staggerd order to keep from breaking and warping. Don't forget to change thermostat good time to replace. Part should be about 50 bucs at your local parts store.
May 02, 2010 | 1999 GMC Yukon
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Not freezing or cooling
You will need to remove the cover in the freezer section, if the fan is not turning, you will have to replace the fan motor, this what allows the cool air to circulate and cool the refrigerator.
Nov 10, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My referator -freezer GE - TBf17 makes a chirping sound in the back
You need to replace the fan motor , pt. # WR60X190 . Remove the food and the ice maker ( if equipped ) , and remove the grill at the top left on the freezer panel ( pops out ) . Remove the 2 screws holding the rear freezer panel on , and remove the panel . You may have to remove the white housing to replace the motor , or just remove the fan mounting bracket screws , to remove the fan for replacement .
Oct 31, 2009 | GE Refrigerators
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
