Question about Car Speakers & Subwoofers
Speakers how could i make or assemble or personalizemy own speakerbox
  • 3 Answers
Re: speakers
First figure out what kind of speaker box you want: Fiberglass, wood, etc.. If you want wood, check your speakers owners manual and determine the volume of the box. should look something like this <a rel='nofollow' href="">Subzero 10 manual</a> At the top you'll notice the Vas, that is the amount of airspace needed. (There are computer programs you can download free, you can enter all that info and it will design a box for you.)<a rel='nofollow' href="">aj designer</a>
You also need to decide if you want a sealed box(easier to build), a ported box( a little harder), or a bandpass( difficult).
After determining the size of the box, go buy the correct amount of wood( 3/4 inch MDF ) from your favorite lumber yard. Also any other needed supplies, Caulk,screws, liquid nails,terminal cups, jigsaw or router, circular saw, ect.
Measure out the pieces and cut, glue, screw, and caulk.
And there you go you have a speaker box.
Now of course, I have oversimplified this incredibly.
you can go to this link for more in depth instructions
<a rel='nofollow' href="">Speaker box</a>
<a rel='nofollow' href="">Status Audio</a>
Posted on Nov 15, 2008
    Problem Solver:
  • 6 Answers
Re: speakers
First you figure out the air space needed for the sub. then figure out how much room you want to take up in the vehicle. If your subs came with the manual, It can then tell you the rest.
Posted on Nov 19, 2007
0 characters
3 Points
How to find a boss speaker serial number for registration
most are located on magnet assembly somewhere if not look speaker over very thoroughly hope i helped
Feb 17, 2013 | BOSS AUDIO SYSTEMS Car Speakers &...
1997 cavalier
Remove the rear seats.
Remove the side panels by the glass.
Remove 3rd brake light assembly.
Pry up on the back dash and remove it.
May 20, 2012 | Car Speakers & Subwoofers
How do i change the rear wiper blade on an 02 siena?
Typically you replace the blade and its' holder assembly. They do wear and will not hold the blade correctly. Usually the blade and holder assembly easily disconnects from the arm...
Feb 12, 2011 | Car Speakers & Subwoofers
How do you take out the subwoofer part?
the speaker should be fixed by screws/bolts, in the front, when assembled someone would have had to fix unit together so think how they built it and work backwards , some speakers are bolted from the rear so look for acces points to get to that the port may twist to release
Dec 22, 2009 | Vibe CBR10 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Can't remove right front hub assembly
Jun 02, 2009 | MTX T-Form04-05 Chevy Colorado Charcoal...
I recently bought a 1994 Camaro with a Kenwood KRC 953 stereo in it. The radio display is working but no sound at all is coming out of the speakers. What is the problem?
Yo most likely have a bad speaker or the amplifier IC inside the radio is bad. More often than not, it is the amp IC.
first double check that you have all speakers connected right and that you don't have a speaker wire that may have an exposed area that could be shorting against the car chassis.
You can check the speakers by disconnecting them one at a time and see if the sound returns to the remaining speakers that are still connected. After checking one speaker, re-connect it and try another.
If the sound returns after dis-connecting one speaker, that speaker is your problem.
If none of this helps, you will need to get it serviced. If you are skilled with soldering and can dis-assemble and then properly re-assemble a radio, this is a very easy fix and I can look up the part number for you of the amp IC. it is also right on the IC itself. If the amp IC is blown up badly, you will see burn markes on it and sometimes a piece of it can be blown right off of it. In that case you will not be able to read the part number.
Normal repair cost for this type of a problem run between $80 and $120 at most shops, depending on the shops rates.
This is a very high end cassette player and in it's day cost about $400 back in 1997 when it came out. But todays car stereos are nearly as good built, and cost much less.
You can get a good car stereo with CD for about $150, cheap ones for $100.
Let me know if you need any further help, and if you found that this information was helpful a good rating would really be appreciated.
Thanks and have a great day,
Jun 21, 2008 | Kenwood Car Speakers & Subwoofers
the subwoofers probley blown, as for getting it fixed - i dont think thats possible. sorry about your loss but a new subwoofer is the way to go
Sep 29, 2006 | Eclipse SW9152 Car Subwoofer
Car Speakers & Subwoofers Logo
292 people viewed this question
Top Car Speakers & Subwoofers Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Car Speaker and Subwoofer Expert? Answer questions, earn points and help others
