Question about Garden
My blower vac will start right up and run for 10 seconds and die. It will do this repeatedly... any suggestions?
  • 10,865 Answers
The problem is in your carbeurator. It runs for 10 seconds on the primer fuel only. Your carb. is gummed up and must be either rebuilt or replaced. OR you might get lucky and ungum it by making it run with some starter fluid.
Posted on Jul 16, 2009
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
Brand new electric mulching blower/vac : cut out after 10 secs.
Electric motors sometimes have circuit breakers to protect them from overload or overheating. Some reset automatically, some don't. But even if you found and reset a breaker, this shoudn't happen 10 seconds after starting a new unit, unless you sucked a branch into it during those 10 seconds! Take it back to the store for a replacement.
Jul 04, 2010 | Garden
Runs 10 or 20 seconds and simply dies
Hello. I recommend that you install a new spark plug and put some carbeurator cleaner in with your gas. i like a product called seafoam. just follow the directions on the container.
Nov 24, 2009 | Husqvarna Forest & Garden #965102302...
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Oct 06, 2009 | Homelite Consumer Products Backpack...
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
