Question about Daewoo Televison & Video
Daewoo DVDS130 player says 'No Disc' after it has already loaded
I have a Daewoo DVDS130 player that I've had for a couple of years. Several days ago I was finished watching a DVD and accidentally hit the Play button on its' remote instead of Enter (I think this was the scenario) and ever since it now says 'No Disc' after I insert a disc and after it says 'Loading'. Tonite it did start to play another disc, but when I hit the 'Play' option on the screen's table of contents, it didn't do anything. I have tried unplugging it, changing discs, etc., but nothing helps. Thank you.
  • 2,200 Answers
Hi
The drive is not reading the disk. This is either caused by a fault in the laser/lens/drive itself or caused by dirt in the drive effecting the lens.
There is a Laser cleaning DVD that you can purchase from any audio shop - its not expensive and useful to have around anyway. I would recommend you try one of these and you may find that it will resolve the problem as a simple and quick fix.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 16, 2009
  • mojoe41 Jan 19, 2011
    i have a the same problem with the p480. with my electronic back ground i have trouble shooted the issue down to the motor that spins the dvd. the 5.6 volt is not getting to the motor. not i am stuck :( if it's down to the micro resister component then i am out of luck. if deawoo give me a new mother board then i can just swap it out. also my contact disconnect/connect switch broke. that explains the clicking noise i've been hearing when i click on close. the sensor is not telling the dvd player that the eye is already at a specific location.
My Road view in the vehicle was working fine...2 day's ago..it's saying 'bad disc' the disc's are all clean and new..I unplug it.. and still saying the same thing.
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
However if the problem persist test the following:
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic.
go to the repair shop FOR fix it.
Oct 15, 2012 | Roadview Rd615 DVD Player
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Luxor tv with dvd player was bought for me from Asda I've had problems with playback of dvds pretty much since I've had it it has a tendency to freeze and not play and on very several occasions it...
Hi Danny.
this could be a couple off things wrong here.
1,could be a faulty dvd player.
2,could do with having a lens cleaning disc put through it.
3,could be a faulty lens reader.
if i was you before i do anything big to it i would run a lens cleaning disc through it and see if it cleans the lens that reads the discs.
if this does not work i would take it back,or get someone to have a look at it for you.
Nov 04, 2017 | Televison & Video
I have a 19" daewoo
First make sure that the disc is not the problem and trigger the symptoms. If you've already confirmed that the fault came from the player itself, you must clean the optical lens from fine dirt(dust) and static electricity build-up by playing DVD lens cleaner to the unit. Dirty optical lens will affect the performance of it. DVD lens cleaner kit is widely available at the market and usually cure most kind of symptoms like this.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 31, 2011 | Televison & Video
My Daewoo dvg-5000n will not recognize dvds
Basically you have two options, as there are many things that can malfunction or become damaged. Rendering it usually un fixable...
Cheap solution
Buy a laser cleaning disc, extremely cheap sold almost anywhere that says electronics. Use the disc in the DVD player.
Expensive
Buy a new one unfortunately, as the repair cost would run you as much as a new DVD player.
Sorry for your misfortune, and don't feel bad I bought a very nice one and it crapped out on me in less than 6 months. Bought a very cheap one and its lasted me the last 2 years and still going strong.
Mar 24, 2009 | Daewoo DVG-5000N DVD Player
RCA DVD videoplayer says loading, then no-disc
I would  appreciate a response to the 10 bucks I sent in a couple of weeks ago.
Mar 22, 2009 | RCA Single Disc DVD Player
Daewood DVD-5700 DVD Player ~ Won't play any DVDs
Hi.
There could be several reasons for this problem.
Since the unit has not been used much the lazer
shouldnt be burned out...but it can mean that it collected dust by not being used.
How is the condition of the disc you tried to play?
Are there children in the family...they love to put things in the tray and load it in. =)
A cleaning kit might help if there is dust on the lazer lens.
Regards...
/Tech5508
Feb 14, 2009 | Daewoo DVD-5700 DVD Player
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
404 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
