Question about GE JRS04 Electric Single Oven
Receiving F3 Code
JKS04 GE single Wall oven will heat for a short time and then the F3
blinks and beeps, Stops heating.
Oven was in the house 6 years ago when I bought the house. How old
is this oven? This happens 5 years ago and the repair person replaced the timer. Should I just replace it?
  • yadayada
    yadayada May 11, 2010
    control pad circuit board failure I think???
  • 6,784 Answers
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Jul 18, 2009
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
My wall oven will heat up and then starts to blink F3
Hello & Welcome to FixYa
F3 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 09, 2011 | GE Profile JKP18 Electric Single Oven
Shortly after pressing the Bake button it starts beeping and F3 shows on screen. In the past, it would do this a couple times and then begin to heat and be fine. Othertimes, it would just stop cooking in...
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
Jan 19, 2011 | Kenmore Ovens
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
When my GE wall oven is in the middle of heating up, I get an F3 edit and the oven keeps beeping. I turned it off and then turned it on again and it seems to be heating again. What part should I look to...
Hello there:
Normally this is due to a bad temperature sensor F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and replace if found faulty
Apr 27, 2010 | GE Profile JK915 Electric Single Oven
One morning the alarm on the GE elctric wall oven began to beep,
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
@$#%$trd
Apr 19, 2010 | GE Profile JTP18 Electric Single Oven
GE Profile Double Oven F1 Error
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
GE JRS04 Electric Single Oven Logo
283 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
