Denon avr 2802 no sound
I have a denon avr 2802, the sound is only output when it feels like it, sometimes a week or 2. when left off for a week or two it seems to come back on. There is not output at all i have tried tuner and all other inputs. But appears dead. Thanks guys.
  • armani_s Jul 17, 2009
    Thanks alot i will try to have a go with it, also i have ordered another yamaha amp. OR i may just have to throw it away. But thanks for your help it is much appreciated!!
    Dal.
  • 44 Answers
SOURCE: Denon Power AMPLIFIER
Try these links
http://ca.denon.com/ServiceCenterLocator.asp
http://www.fredsoundofmusic.com/denon_audio.html
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
  • 54 Answers
SOURCE: DENON AMP OVERHEATED
More than likely, you popped an amp channel. My experience is that it is the one closest to the middle of the heat sink.
Take it to an authorized service center, and be prepared for a large bill. Good luck...Rob
Posted on Mar 03, 2008
jack_daniels
  • 304 Answers
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Posted on May 24, 2008
  • 30 Answers
SOURCE: denon avr 1507 no power
still under factory warrenty if its actualy a new model and a new purchase.
Posted on Aug 01, 2008
  • 5 Answers
SOURCE: Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Posted on Aug 29, 2008
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
Feb 09, 2018 | Denon AVR-2802
I have a Denon AVR 2802. No sound output when adjusting master volume knob. When trying to solve the problem, I found out that I can achieve sound output by pressing the CH vol button and adjust individual...
try to reset. Unplug the unit, press and hold speaker A and speaker B buttons and plug the unit in outlet. If doesn't help, the unit may have a problem with microprocessor or dsp boad and need to be serviced at a repair shop.
Oct 04, 2011 | Denon AVR-2802
I have denon avr-2802.. suddenly no sounds will come out but the power ok.. help me pls..
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2802-Receivers-manual/id/363bh830/t/2/
Is it silent for ALL inputs including the Test Tones?
Page 33
Function incorrect, Muting, Tape or EXT Input on when it shouldn
Feb 19, 2011 | Denon AVR-2802
I am trying to connect my wii to my denon avr-2802 using the wii's composite cables. i get sound but no picture. help.
After connecting the Wii cables, connect a video cable to the "monitor out" connection to a compatible input on the TV.
Feb 15, 2010 | Denon AVR-2802
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
Technical Problem on my Denon AVR 2802
How good are you with electronic repairs...? Do it if only you are confident...
The way you describe you problem it seems more like poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Also, look for any connections that appear to be grasiny or have rings and resolder them too.
Alternatively, suggest that you take it to the Denon service center closest to you.
Best of Luck..
Mar 05, 2009 | Denon AVR-2802
After playing my AVR-2802 Denon a while approx 3-4 hrs the sound output juts turns off, after letting it cool down a while it will resume playing ok , then repeats the cycle of loss of audio output.
Seems to be a heat related issue, when it " cools down " awhile it resumes audio output? Be sure you are allowing air circulation around the receiver, I am note sure but I do not think Denons have inboard fans, you could try a ciculating air fan on the unit after playing it for a couple of hours if the receiver feels hot.
Jan 30, 2009 | Denon AVR-2802
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Jul 22, 2007 | Denon AVR-2802
342 people viewed this question
 Grubhead
Grubhead
