Question about Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
Icemaker makes ice but wan't despense, also water wan't despense
I have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Posted on Feb 24, 2012
  • Bill Allton Feb 25, 2012
    how do you take out ice maker?
  • 686 Answers
SOURCE: Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Posted on Feb 26, 2009
daddy1264
  • 76 Answers
SOURCE: replaced water filter now icemaker not working
check to see if the direction of the water flow is correct on the filter
Posted on Dec 31, 2008
rylee_smith
  • 8619 Answers
SOURCE: Ice maker only makes cubes. It will not make crushed ice.
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • Posted on Jan 24, 2009
    ginko
    • 19396 Answers
    SOURCE: icemaker not filling with water
    Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
    The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
    If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
    Enter the model number on one of two websites below to get parts and diagrams for your appliance:
    Appliance Parts From PartSelect
    Appliance Parts Pros
    Posted on May 22, 2009
    SOURCE: Ice maker stopped working
    Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
    Posted on Jan 11, 2010
    Ice maker not making ice
    check the compressor if its running or not if not check its low pressure switch may be the unit is lack of refrigerant or if this one have a PC board change it maybe the old PC board is not functioning thats why the compressor is not running
    Mar 14, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
    Amana ARB9058CB refrigerator water despenser weak and ice only half-sized
    If your water pressure is good everywhere else in house, the refrigerator water valve is most likely causing your problem
    Oct 26, 2017 | Refrigerators
    It despense water, but does not make ice
    Either the water valve is bad or the icemaker is bad, assuming it is turned on.
    Check the valve with the wires off with an ohmmeter.
    If it shows continuity, the icemaker is bad.
    Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
    Not getting water to ice maker or water despenser
    1st make sure the water is on. Then advance the icemaker. What model do you have. If you dont have a electrical display then remove the cover and turn the smaller gear with a 5/16 screw counter clockwise. The ejector blade will get to 2 oclock when it will go on its own. When the ejector blade reaches 10 oclock then it will call for water. U-line icemakers have to reach temperature before it advances the icemaker. Again what model is it?
    Jun 30, 2009 | U-Line Refrigerator Ice Maker
    The water despenser works but the icemaker doesn't
    The most popular problem area is the fill tube by the icemaker. Check for an ice build up inside of the tube. If that isn't the problem, you must ck the coils on the filter valve and the coils on the supply valve with an ohm meter. Check for kinked water lines, leaky water lines etc. An after thought, make sure that the icemaker itself hasn't got a huge bunch of ice it built up and can't dump out.
    May 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
    May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
    Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
    1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
    Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
    No water or Ice
    chances are your waterlines and motor are frozen, which indicates you may have a leak somewhere, causing ice build-up
    Jan 31, 2008 | GE GSH25JFR Side by Side Refrigerator
    Hotpoint side by side Model HSS25GFPJWW
    Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
    Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
    FYI GE customer Care is useless
    Jan 03, 2008 | Refrigerators
    Side by side fridge / freezer - Icemaker problems
    What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
    Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
    Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
    334 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
