Question about Passport 9500i Radar/Laser Detector
It doesn't sound
I cant get my escort passport to alert
  • 134 Answers
Your 9500i likely has a blown speaker. Contact Escort about sending in your RD to have its speaker replaced.
Posted on Aug 01, 2009
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Service required
If this sounds like a dashboard alert for a fault then you need to have your car diagnosed by a computer to find the exact fault.It works out to be cheaper..Check digimotolite on google ...
Jun 15, 2009 | Passport 8500 Radar Detector
My passport 8500 stays on Full Alert
First you should try it in another car if possible. It sounds like an electrical problem. You need to rule out if its the car or the radar detector.
Open the end of the power cord it unscrews, check the fuse in it to see if its blown.
Ive also seen the screws loose that hold the circuit board down cause problems. If its out of warranty now, there should be a screw on the bottom usually under a sticker. If you peel that back and remove the screw, and lift the bottom off..Tighten any screw you see holding tbe board down, dont tighten it to hard. Then replace the cover.
Post back after you try some of those, let me know if it still does it.
Mar 18, 2009 | Passport 8500 Radar Detector
Passport 8500 will no longer switch to LOUD mode
Try doing a factory reset as described in the user manual since it is possible that a power fluctuation has somewhat corrupted the internally saved user settings.
Mar 02, 2009 | Passport 8500 Radar Detector
My passport 9500i has no sound
The little speaker in it is defective. Mine does the same thing and I discovered the defective speaker when I opened it.
It is now going to Escort to be reparied.
Jan 07, 2009 | Passport 9500i Radar/Laser Detector
No sound
The Piezoelectric speaker has gone bad. Escort can replace it.
Dec 28, 2008 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Continuous alert
About the only thing to try with the Escort 8500 and the x50 is to do a full reset. Hold all 3 buttons down while turning the detector on. I believe Escort will still work on it, there will just be a service charge with no warranty.
Sep 14, 2007 | Passport 8500 Radar Detector
Passport 9500i Radar/Laser Detector Logo
423 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
