Question about Frigidaire ATF6000ES Front Load Washer
Does not pump water out model fwt445ges2 - Frigidaire ATF6000ES Front Load Washer
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 16, 2009
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Mod.fwt445ges2 Went into spin with out of balance load and shut down. Will not start or run in any cycle. Door latches, light comes on, timer doesnot advance in any setting nore does pump.
Initially, try to manually unload contents including the water. Thereafter pls try a full hard reset? IThat is unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches as well as user settings and configurations.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
Jun 06, 2008 | Frigidaire Washing Machines
Fwt445ges2
Hello Ralph - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Since the unit is humming, that typically means that either the drainage hose or pump may be clogged and/or needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jun 25, 2013 | Frigidaire FWTR445R
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
May 27, 2009 | Frigidaire Washing Machines
Frigidaire frontload washer
you dont need to buy the shaft, "spider".it has a lifetime warranty on the inner tub and should be replaced by frig. what you need is the entire tub as the shaft is not available seperately. if you cant get this under warranty then i would suggest buying a new unit as the outertub and bearings are what is worn causing your noise in spin. you may have to pay a warranty dealer to get the tub covered, but the whole job is very labor intensive and most people cant do it, even if you are good with tools. call frigidaire and see if they will cover the repairs first.
Dec 28, 2008 | Washing Machines
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
275 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
