Question about Hunter 33201 Humidifier
Air/no moisture New humidifier, blows air but no moisture on any setting
You may not see moisture come out but you can tell if the canister isn't emptying that it's not working. I have the same problem. Did you get a good answer Beth?
Posted on Jan 07, 2010
  • 114 Answers
The reason why you might not see the moisture coming out cause it's a cool mist humidifier. to test your humidity in your house you might want to get a humidistat which will letyou know if your getting the humidity in your room or not. now if it's a warm mist you will see it but it's a coolmist so you won't see moisture coming out.
Posted on Aug 20, 2009
2 Suggested Answers
  • 123 Answers
SOURCE: no moisture
Is the level of water dropping? If so, the humidifier is working. If you have a cool air humidifier you won't see any steam or anything at all. You will just feel cool air. Watch the water level and see what happens.
Good Luck.
Posted on Apr 18, 2008
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Feb 08, 2011 | Robitussin Cool Moisture 1 Gal. Humidifier
I hooked up my humidifier, and everything seems to be working fine, but I was surprised to see how much water accumulates from the drain...what is a normal amount of drainage over ther first 24 hour...
There is no "standard" amount of water that will be used.
This is a flow-thru type humidifier, which means water runs through an evaporative pad and air blows over it to evaporate the water and humidify the house.
The amount of water the unit uses will depend on the house water pressure, humidistat setting, outdoor conditions, the condition of the humidifier pad, the temperature of the air flowing over the pad, the size of the house, the number of people in the house, the amount of of moisture-absorbing material in the home like textiles, carpeting, drapes, furniture etc., and temperature in the house. There are other factors as well.
The humidistat should be set to the lowest point possible and still provide some humidification (so you don't get zapped by touching metal objects or light switches). Some stats are calibrated in percent, while others simply have numbers on the dial. If you have the stat set too high, you may see frost forming on windows or around doors, in which case the setting should be lowered.
Feb 17, 2010 | Honeywell HE220A1019 Whole House...
No matter what setting is put on furnace humidifier, moisture forms on windows.House is only 6 years old and does have a lot of windows.
Hello WPwilkers, Well there's good news and good news!
First off, you should probably use the lowest possible setting as your house being so new, is likely pretty "air-tight" and as such, doesn't have a lot of air infiltration (gaps and drafts) hence the reason you're seeing moisture on the windows.
Now, I would also use a hygrometer, just like your parents likely had hanging on a wall somewhere in their house. It will give you a better idea of the moistur (humidity) around the house. My guess is that you're already at the 60%+ level of humidity.
I suggest that you turn "OFF" the furnace mounted humidifier, until you no longer see moisture on the windows. That will allow the house to adjust and get back to normal humidity levels.
Then you can start by setting the humidifier on the lowest possible setting and keep an eye on the moisture levels in your coldest room of the house, as that is where you'll first notice the excessive moisture on the windows (just the way it works - cold rooms get condensation on the cooler windows first).
If you don't have the humistat (the control for the furnance mounted humidifer) mounted next to your heating and cooling system thermostat, you should do that - it will make it easier to adjust and also will provide a more accurate reading for the humifier to operate properly.
Some Thermostats have the ability to add a humidifier on it for integrated controlling of the furnace humidifer. Check your Thermostat and Furnance owner's manual for details.
I used to have the same problem and found that by moving the humidifer control from the utility room (mine was in the basement of my house) to the living space, it made a big difference. Since most people's homes have unfinished basements and that's where the HVAC system is located, it doesn't get the same humidty readings as an occupied living space.
The other reason that you tend to get moisture (condensation) forming on windows is that the Percentage of humiditfication is set manually with the humidifier control, and yet, the outside (and inside) air temperature vary and the difference between them can cause the humidity levels to go from very dry to very moist, in a day or two.
I tend to wait until I notice that the air inside the house is getting dry and then turn on my humidifier, once the cold winter days have taken hold. In summary, nothing wrong with your unit, just mother nature and a well built (most air-tight) home are giving you higher levels of condensation than most older homes. Gradual adjustments, once you turn the humidifier off for awhile, should get you the desired results.
I hope you find this Very Helpful and best regards!
Dec 17, 2009 | Honeywell HE365 Humidifier
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
WHAT SETTING DO NEED MY BASEMENT IS MOLDY %SMELLY I HAVE IT SET AT 35
Hi! is it a humidifier or dehumidifier? if you want to remove mold you need a dehumidifier to absorb the moisture on the air. provided that the unit is capable of absorbing the moisture on your basement floor area. because a typical dehumidifier can only accommodate a 21 square meters floor area.
Sep 01, 2009 | Aprilaire 550 Humidifier
Not pulling moisture from the air
Humidifiers put moisture into the air you want a dehumidifier
Aug 22, 2009 | Humidifiers
Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Apr 10, 2009 | Honeywell Humidifiers
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
No moisture
Good Luck.
Feb 23, 2008 | Hunter 33201 Humidifier
The fan blows but the humidified air stops after 2 seconds?
This is an old post, but you can make sure the humidity adjustment is full high. Perhaps it is defective or possibly, the environment is as humid as the high setting will allow.
Feb 08, 2007 | Bionaire BU4000-UC Humidifier
Hunter 33201 Humidifier Logo
464 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
