Question about Panasonic PT-47WX49 47" Rear Projection Television
Can someone tell me what watt and ohm resistor goes in slot r7006,r7001,r7002,r7003,r7004 for a panasonic pt53wx42f
  • Panasonic Master
  • 8,617 Answers
R7001, R7003, R7004, and R7005 are all 82 ohm 2watt resistors R7002 amd R7006 are 120 ohm 2watt resistors
Posted on Jul 16, 2009
What size transistor goes to each convergence chip - location number on board (i.e., 80 goes to r7001, etc.)
Not sure what you are talking about, this set uses two of the STK-392-110 CONVERGENCE IC'S.
There are no transistors that go to individual pins on those chips directly---you are talking about the light blue resistors that do go to individual pins---most are 2.2 ohm and 1/2 size and those are about the only ONES THAT EVER FAIL--HAVING FIXED NEARLY 200 OF THIS EXACT MODEL SET, never seen more than one of the 2.2 ohm resistors bad---
If you want to make sure each is the correct value, Google for the full service manual by model number, no one carries those number to value with location numbers in their pockets, IF ANY OF THE 2.2 were bad set would shut down and constantly blink 3 blinks at the power light.
Dec 14, 2012 | Panasonic PT-47WX42 47" Rear Projection...
Tv wont turn on
You need 2 STK392-110 Convergence ICs and possibly 6 2.2 ohm 2watt resistors. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the ICs, resistors and the CD with instructions. The PT47WX42 convergence kit is the correct one for your model.
May 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Help follow-up
scott737,
There is no kit for your repair.If your original IC's = STK392-110...
quality Sanyo-made will cost you $14.00 - $16.00 each.If you buy Panasonic packaged IC's,the part # is C5AA00000203 and they cost about $30.00 each. Use an ohm meter,your eyes and nose to locate burned resistor(s).Usually one or two 6.8 ohm
1 watt light blue color a total of twelve, I think.....However,your next step is to order / purchase first grade IC's = Panasonic is going to be your best choice.........and some 6.8 ohm 1 watt
resistors.....
Terry.
Aug 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
RESISTORS
The value of those resistors is 0.27 ohms 5% 1 watt.
Click here to find the resistors.
Jul 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Great
There are 3 ratings for the resistors and there are 4 of each rating for each IC they are 2.2 ohm 1watt 2.2K ohm 1 watt and
3.3K ohm 1 watt. You can get replacements here.
http://servicemanuals.vstore.ca/
Jun 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I had projection tv.modle#pt-47wx49.i had convergence problum.i change both big ics.one resistor is blown out. what is the valueof resistor place on R7050,or R7001,or R7059.please help me.
R7050 and R7059 are both 2.2ohm 2watt Resistor R7001 is either 82 or 8.2 ohm if you give me the colors of the bands on that resistor I will let you know for positive what the value of R7001 is
Apr 26, 2008 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
CT-27SX11E Fixed but need advice on R value
i would not recomend replacing the 7w with the 5w, beacuse the resistor will allways run hot, hotter then the resistor should be. the resistor could possible melt anything that touches it & will not last as long as the original before it goes bad. find a 7w, if just for safty reasons.
Nov 01, 2006 | Panasonic CT-32D12D 32" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
