Question about Sansui DTV2760 27" TV
How do I turn on closed captioning on my sansui tv?
I dont know the model number of the tv,but,on the remote it says closed captioning decoder and under that are these tiny numbers 076d0fm010
4 Suggested Answers
SOURCE: Sansui TVM1316
try channel 65 and connect via antenna cable.
Posted on May 30, 2008
  • 13433 Answers
SOURCE: Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Posted on Jun 28, 2008
  • 106 Answers
SOURCE: want to program Dish remote to run sansui tv
  • what kinda off provider!! there is a web sight go under universal remotes and look up the remote you have there should be a code for your remote this should help!!!
Posted on Mar 26, 2009
  • 126 Answers
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
Posted on May 18, 2009
0 characters
1 Points
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like to buy the tv original remote.
Apr 27, 2011 | Standard (CRT) Televisions
Close captioning is on and there is no remote, other than the cable box remote - how do we turn it off
Without a remote for the TV or possibly a universal that you can program, you usually can't turn off CC..Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sansui DTV2760 27" TV
How do I turn off the close captioning on a Sansui TV using an RCA universal remote
codes for sansui from an rca remote are 1191,1208,1282. while pressing and holding the tv key, enter one of these codes. release the tv key and then press on-off key. then press tv key then on-off key again. if set turns on and off, we got the right code. then just use your menu to find closed caption and adjust from caption or text to off.
Nov 14, 2009 | Standard (CRT) Televisions
Black box blocking picture
This is probably the text box function of the closed caption decoder. Turn off the closed captioning. I hope this helps you.
Apr 10, 2009 | Sansui DTV2760 27" TV
Can't get closed caption off of television
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Mar 05, 2009 | Sansui DTV3200 32" TV
How do you keep caption off the screen?
Use the tv/cap/text button on the remote to turn off the closed captioning.
Jan 31, 2009 | Sansui CDVD1310 13" TV/DVD
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Sansui 27
try togo to men then from there you can see the features and find the close caption
Nov 01, 2007 | Sansui DTV2760 27" TV
Closed Caption
If you dont have the original remote, its going to be kinda hard, as universals wont work on this funtion on this set. The original remote has a button marked "CC" toward the bottom of the remote. Maybe you can borrowe on from a friend or a local sales store just so you can turn off the closed caption.. You can purchae a replace remote that is exactly the same as the original at and enter your model number.
Sep 14, 2006 | Philips Magnavox MT1905B 19" TV
Sansui DTV2760 27" TV Logo
57 people viewed this question
Top Sansui Standard (CRT) Televisions Experts
Level 1 Expert
rugby prop
Are you a Sansui Standard (CRT) Television Expert? Answer questions, earn points and help others
