I can not turn on the unit with either the power button or the remote. I have to disconnect the unit by pulling the plug and then puting in the plug. I can then press the power button and it turns on and then off, After that I can turn it on normally
  • richoo8 Jul 16, 2009
    I am not having a printer problem. My problem is with a Panasonic DMR EZ47V dvd/vhs recorder.
    Top Expert:
  • Office Equip... Master
  • 76,070 Answers
There is no generic problem, these kinds of problems are unique to some makes and models of printers, need make and model to help u further
Posted on Jul 16, 2009
  • yadayada
    yadayada Jul 16, 2009
    ok but the heading of your post says "generic problem for printers", do u understand the confusion on my part? anyway the power button on your unit is no more than a momentary ground circuit that tells a small IC circuit to "boot" up the machine for use, just like a computer does, the problem is that the circuit that actually turns the machine on is defective, when u disconnect the system power you reset everything and it works, this is common with solid state circuit failures, you will need to have the the unit repaired as there is no external fix for this problem.
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
Unit in room displays fault code -0 and 6. Unit is a Sharp eco inverter AY-XP07ER. Unit runs for a few minutes and cuts out showing fault code.
Do not allow the signal receiver window to receive strong direct sunlight, since it can adversely affect its operation. If the signal receiver window is exposed to direct sunlight, close a curtain to block the light.
Using a Fluorescent lamp with a quick starter in the same room may interfere with transmissions of the signal.
The unit can be affected by signals transmitted from the remote control of a television vcr or other equipment used in the same room so make sure if anything recently added to the room is un plugged for testing purposes.
Do no leave the remote control in direct sunlight or near a heater also protect the unit and remote control from moisture and shot which can disclour or damage them.
Check whether the remote control batteries have become old and weak. (replace with new ones)
Try to send the signal again with the remote control pointed properly towards the units signal receiver window
Check whether the remote control batteries are installed with the polarites properly aligned
This could also be a result of the error locking out the remote as well so keep this in mind.
Also if possible unplug it and let it sit for atleast a day then plug it into a different outlet (if possible) to see if there is any change in the units functionality.
After that I would have to say check the area around the base of it and make sure that there is no moisture damage to the unit.
A good cleaning could be in order as well.
then if all else fails and the error presists contact customer service with the issue of the machine they will know what the error codes are.
hope that helps let us know how you make out.
Aug 02, 2008 | Sharp Heating & Cooling
What remedy to turn the unit operational
Check the batteries of your remote control, replace the batteries, press power button. You should hear a click from the unit. If no sound from the unit, check if there is power going to your unit. If no power, reset the breaker by pulling the handle to off position and then switch it on. For disconnect switch replace the fuse and then switch it in on position.
Mar 04, 2016 | Heating & Cooling
Amplifier will not turn on, from front panel or remote.
Suspect this is a protective feature of the unit. If the feature is malfunctioning, the amp will have to be repaired. To troubleshoot, try disconnecting everything including power and allow the unit to sit for a few minutes. Then plug in power and turn the unit on. If it powers up, it would appear the problem is related to a wire or connected device.
May 20, 2014 | TOA Electronics - A724 - A-724 240W Mixer...
Operating instructions for EM-2R power meter. it has 3 plug-in sender units with remote reader. How do I resynch the senders and reader after replacing battery in reader? Cheers DaveK
I have what appears to be the same device. My instructions list the following method:
1. turn off or disconnect all the remote monitors.
Use the code button on the display module to set the channel. It displays 1 --:-- for channel 1.
Plug in the first remote sensor into the power outlet and press and hold down the SET button until the LED flashes.
The receiver will show numbers where the dashes were in the display.
Change the channel on the receiver to 2 withb the code button, it displays 2 --:--.
Plug in the second remote sensor, press the set button till the LED flashes.
Repeat for channel 3 with the third remote sensor.
This is the same method used to set them up the first time. Having to turn off or unplug the device is the unintuative bit. I assumed it would reconnect after replacing the batteries.
Dec 19, 2010 | Kitchen Appliances - Others
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Readout screen says can't scan or fax,turn off and try again,
Please follow the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
* Turn on the printer/unit and disconnect the power cord from the unit then perform the reset.
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
May 24, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
After motor work starter runs when power applied
sounds like starter solenoid is staying energized sending continued power to starter. need to make sure you plugged the right wire from the starter button and not another hot wire w/ fulltime hot. also if thats ok need to test for power turning off to solenoid when releasing button. if thats ok try tapping on solenoid. lastly, make sure your positive cable from battery is hooked to starter solenoid, then another hot cable(longer) hooks from solenoid to starter, if you hook long hot cable directly from starter to battery, starter will continueous spin.
Feb 19, 2009 | 1996 Honda VT 1100 C Shadow Spirit
Power off and on again and then no sound present
i assume pressing the source button on the remote control is how you normally turn it on again, (ie video FM CD etc)
it might be that moving the unit to the cabinite the battery power in the remote ( its not infra red its radio wave thay are not picked up by the fm antenna ) is insufficient to wake it up again,
change the batteries in the remote or try to see if there is some weird reason the cabinet is preventing these remote control radio waves from being recieved by the head unit, try opening the door and bring the remote within a few inches of the head unit and see if it turns on when you pres the cd button.
see how you go from there mate
Nov 30, 2007 | Bose Lifestyle 12 System
jasbo
jasbo
