Blower doesnt work at all. if you move the plug around it will work for a while, and how do you change the plug.
  • 2,418 Answers
It is fairly easy to replace the cord, you will have to open the case. Follow the wire to the Control board. Cut the cord close to the control board, but leaving room to work with, at the wire ends, (leave 3in or so to work with) or undo any screws, match your new cord to the old by striping back the main insulation, checking the colors of the wires, match the wires color for color. Get some wire nuts from H-depot or Lowe. Twist the wires together, screw on the nut put back together pulg it up.
Posted on Jul 16, 2009
I changed my plug wires and reconnected the ground cable and now my blower fan doesnt work
YES , common sense is a good thing, don't you agree ? take your time , you'll figure it out !!!!
Jan 15, 2013 | 1994 GMC Sierra
Blower motor doesnt work
Is it getting power? Blown Fuse, Bad Switch, Bad Wiring/connections. Check the DC voltage, sometimes the fuse looks good but isn't. Even a cheap voltmeter from ie Northern Tool will do the job.
What does a resister plug have to do with the blower motor?
Jun 22, 2012 | GMC Canyon Cars & Trucks
Pontiac montana 2000 general fan (all air-hot and cold) doesnt function changed the fuse and now only works from settings 3-5 and change the heater relay is my fuse labelled 'air" not the right...
there is a blower motor resister which controls fan speed i believe its located pass side of dash by blower motor has one plug about 5 wires red ,orange .blue yellow
Feb 09, 2011 | 2001 Pontiac Montana
Front heater blower low speeds dont work
if you have just high speed, you need to change resister, usually in plenum case to keep it cool. If it goes again, change motor, it is drawing too much current
Jan 16, 2010 | 2002 Chrysler Town & Country
Volvo air conditioning doesnt work s60
you need a blower motor resistor
Oct 30, 2009 | 2001 Volvo S60
The pointer doesnt move sometimes AT ALL
It may be in "accessibility" mode.
Tap the touchpad five times. A message will appear. Change it to normal mode, disable accessibility option.
Sep 30, 2009 | Compaq (153515-001) Touch Pad
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
A-c switch on my 2005 colorado only works on high speed
I had the same problem on my 2005 Colorado. I changed the blower resistor but still had the same problem. I had no voltage at the blower except on high. After talking with the local Chevy dealer, I found the plug-in connector that goes to the resistor had a burnt place on one of the terminals. AC offers a kit that you can splice into your existing wiring. Took me around 30 minutes to change. Costs around $50. So be sure to check the plug before changing anything out.
Sep 05, 2008 | 2005 Chevrolet Colorado
1977 Ford F-250 removing heater blower fan
hello your heater blower fan is located in your heater box pass you will see a stop sign shaped flat flared end metal piece about 6inches diameter all the way around held in with either 6 or 8 1/4bolt heads unscrew these unplug wire feed pry lightly away from box fan assembly will come right out if your blower moter doesnt come with plastic fan fins you will need to use the old one usaully held on with a clip once removed slide off the fan shaft install to new motor reintall if no gasket take black permatex apply a thin coat around outer edge of new fan tighten plug power back on done goodluck
Jul 17, 2008 | 1997 Ford F250 SuperCab
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
