TECO AIR CON SPLIT SYSTEM - THIS SYSTEM WAS INSTALLED BY A TENANT WHO HAS TAKEN THE MANUAL WITH THEM WHEN THEY LEFT THE HOUSE. THE NEW TENANTS ARE SAYING THAT THEY ARE NOT GETTING ANY WARM AIR FROM THE AIR CON. CAN YOU PLEASE HELP ME WITH THIS PROBLEM AND WOULD YOU KNOW WHERE I MIGHT BE ABLE TO GET A MANUAL. KIND REGARDS SHARON DANIELS RE/MAX IMPACT REAL ESTATE sharon.daniels@remax.com.au
  • impactnarang Jul 16, 2009
    Hi Mat, Will have to go to the house to get the model number then I will email this to you.
    regards
    Sharon
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Whats the model number? I should be able to send you the manual, providied that I know the model number
Mat
Posted on Jul 16, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
I have a teco split system which stopped working the stand by light has gone off too. Can I fix it.... Lost maual
call teco tech support and they will send you a free operator manual and probably refer you to a local service shop.
Jan 04, 2015 | Heating & Cooling
Air conditional water drip
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Apr 20, 2014 | Sanyo Split System Air Conditioner
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Operating manual for Teco inverter air con LT1107V1
I couldn't find my manual for the split air con Could someone please tell me how do I find the manuals online?
Jan 21, 2012 | Peugeot Mana 850 Motorcycles
Installation manual required for teco split aircondtioner. Reverse cycle LS0909Y. I have operation manual but not sure how to install and wire up. Many thanks.
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Oct 06, 2009 | Heating & Cooling
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Heating & Cooling Logo
1,502 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
